The 35mm CAMERA RECOMMENDED PANNING SPEEDS by The ASC Manual
panning speed strobing jitter
#1 Igor Trajkovski
Igor Trajkovski
  • 311 posts
  • Macedonia
Posted 06 November 2013 - 06:55 PM
After looking of ways how to eliminate judder / strobing when moving the camera
and shooting progressive (read: 24, 25 fps) i came across
the 35mm CAMERA RECOMMENDED PANNING SPEEDS tables in The ASC Manual.
Tables with the same data can be found also on this LINK.
I wonder how these values are established.
Formula? Testing?
Best
Igor
#2 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 07 November 2013 - 08:28 AM
From a formula relating shutter speed to rate of angular movement across the frame. It will be based on an assumption of how much subject movement is needed to avoid the appearance of strobing.
