Avoiding HMI Flicker
No replies to this topic
#1 Ronnee Swenton
Ronnee Swenton
  • 15 posts
Posted 15 November 2013 - 01:53 AM
Hey guys,
I've been doing some research to avoid any flicker issues I may have with my magnetic HMI's.
So far, from what I've gathered throughout searching these forums and elsewhere, I've come to this conclusion:
I should run my 1200 magnetic HMI on a Honda EU Inverter genny (thanks Guy for the article) to avoid fluctations in hz. This will give me a very acurate 60hz cycle. My camera's shutter should then be set to 1/60 to prevent any possible rolling flicker.
At this point, a few last questions I have are whether or not I would benefit from using 24fps rather than 23.976. Is this redundent if my shutter is set at a definitive 1/60 (as opposed to an angle equivalent)? Will 24fps avoid timecode sync errors (assuming all devices are synced correctly)? and in your personal experiences is a 1/60 shutter less appealing than the standard 180 degree or 1/48 shutter?
My end format will be 23.976 HD for television. I understand there will be a minor speed change in editing, and I'm fine with that if it saves trouble in production.
Thanks again,
Ronnee Swenton
