Anyone use an Aadyntech Punch?
#1 andrew ward
andrew ward
  • 269 posts
Posted 16 November 2013 - 05:33 PM
Seem cool but i cant find any real world reviews to find out what the actual problems are...
#2 Christopher M Schmidt
  • 31 posts
Posted 19 November 2013 - 05:29 PM
I have used the lesser power one which they compare to a 1.2k HMI.
Its is green the CRI is probably a little sketchy (I would guess 80-90ish) and as you dim it gets worse and worse
The pattern of the light is also sketchy ....its not at all a single point source inside the fixture is an array of LEDS about 1ft x 1ft and if you try to use doors to control the light you can see the pattern of the LED's.
That said if you are in place where power draw is a problem and you are diffusing the source I think its great. I used one on a doc style thing and aside from problems with a little green spike it was fine and the small green issues colored out no problem at all.....I think if you know the problems going in it can be a great tool....and the rental was cheap too.
#3 andrew ward
andrew ward
  • 269 posts
Posted 20 November 2013 - 03:42 PM
Ah bugger.
Probably not worth buying one then :(
Thanks for taking the time to let me know.
#4 Bobby Holbrook
Bobby Holbrook
  • 1 posts
  • Lafayette Louisisna
Posted 20 November 2013 - 04:44 PM
It's a good Liight, But I really perfer the Brite Shot Luminator. I've done review on it and here is a link
I simply can't see going on set with out one now. You can Rent or Buy..And NO I do not work for them
Bobby Holbrook
