Need a recommendation for light
#1 Allen Achterberg
Allen Achterberg
  • 437 posts
  • Santa Maria CA
Posted 15 December 2013 - 02:11 AM
I will be shooting a lot of videos of some RV's Toy Haulers etc, Tight spaces and need a good exposure without diming the ISO. I have to close the blinds etc because looking out the windows you see other units and its just not pleasing. This makes it pretty dark. I need something battery powered and portable. The spaces are very tight, I need it to be daylight balanced and soft much preferred. I really wanted to find some sort of Battery Powered 500w Daylight balanced Chinese Lantern. But open to anything recommended. Need to order ASAP. Don't worry about budget
Allen
#2 Mateo HC
Mateo HC
  • 1 posts
  • Montreal
Posted 15 December 2013 - 12:43 PM
What about Konova or Ikan? They have LEDs whit v-lock battery plate
#3 Ged Murphy
Ged Murphy
  • 2 posts
  • United Kingdom
Posted 24 December 2013 - 03:36 PM
KinoFlo Celeb 200 with a double V-lock adapter (Hawk Woods XE-70) and cable to join the two together should do the trick - with two batteries of course!
If space is really tight ARRI LoCaster, with a V-lock to XLR adapter will also do the job.
#4 dan green
dan green
  • 6 posts
  • canada
Posted 14 March 2014 - 02:09 AM
I bought Camtree Beam lite to brighten up my pictures at very less price. They're of lightweight and quality is also good.Very bright and Intensity is also very high. These LED Lights may fit in tight space.
#5 andrew ward
andrew ward
  • 269 posts
Posted 14 March 2014 - 03:09 AM
Shill
#6 Alexandre de Tolan
Alexandre de Tolan
  • 115 posts
  • Sevilla, Spain
Posted 14 March 2014 - 06:27 PM
Have you consider 12" LanternLocks? I know they are probably larger than a single fixture but 12" isn't that large and you end with the Chinese lantern you're looking for.
You then can use a high output daylight balanced CFL which will provide enough power to light a tight space to a decent f/stop and can be powered by a battery belt if you have an assistant with a boom pole to operate it or with a V-Mount with the right adapter plate.
#7 andrew ward
andrew ward
  • 269 posts
Posted 14 March 2014 - 06:42 PM
Icelight.
