Can we talk about the post/grading on The Desolation of Smaug?
peter jackson hobbit Pro-Mist filters digital softening
#1 Richard_Swearinger
Richard_Swearinger
  • 27 posts
  • Des Moines Iowa
Posted 16 December 2013 - 04:05 PM
In Variety, Peter Jackson said that in The Desolation he worked to address criticisms that Part 1 looked too much like high-def video:
By tweaking the picture digitally, he says, he was able to keep the advantages of HFR, he says, but tone down the hi-def-video look. “I was experimenting all the time and trying different things. It’s to do with diffusing the image a little but, using what’s called a Pro-Mist; it’s the saturation of the color. Scene by scene I’d make decisions and choices as to which way to go, so it wasn’t really one magic button to press.”
When I saw the picture last night (in 2D) some of the scenes, even though sharp, seemed on the higher side with regard to halation and flare; they looked almost milky, some of them.
Now, my question is this: Is it better to under-difuse a little because you know the downstream technology will multiply any effects you add? Or is it a case where the digital diffusion you see on your monitor is exactly what the audience will see?
#2 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 16 December 2013 - 11:07 PM
I can't imagine that Diffusion was able to solve the problems that the first film had. That was entirely down to the 48fps. If you choose to shoot and project in a way which is essentially Interlaced as far as the look goes, your end product is always going to look like a daytime soap opera. Using Promists was always one of the 'magical' solutions that people had for making video look like film. It didn't work back in the day of interlaced, and I'd be amazed if it worked now.
HFR was always a solution in search of a problem in my opinion.
#3 Brian Drysdale
  • 5282 posts
Posted 17 December 2013 - 09:31 AM
Even film at high frame rates can look like video. This was one of the comments about the original Showscan
#4 Will Montgomery
Will Montgomery
  • 2106 posts
  • Dallas, TX
Posted 17 December 2013 - 10:04 AM
Issues were highly visible in the river chase seen where the water splashing looked strange; I'm sure it had to do with the frame rate. My 10 year old said that the "film & effects looked bad on that part…like they used a cheap camera or something…"
Out of the mouths of babes...
Also tagged with one or more of these keywords: peter jackson, hobbit, Pro-Mist filters, digital softening
