Telecine DIY
9 replies to this topic
#1 Mattias Norberg
Mattias Norberg
  • 24 posts
Posted 29 December 2013 - 01:01 AM
here is my telecine in action :)
  • 3
#2 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 29 December 2013 - 03:39 AM
Looks good! Crazy motor setup! What software are you using? And what hardware do you use to trigger it?
#3 Mattias Norberg
Mattias Norberg
  • 24 posts
Posted 29 December 2013 - 05:15 AM
in the video i use IC Capture 2.3 you can download it here
http://www.theimagin...port/downloads/
software called FireCapture works to you can download it here
http://firecapture.wonderplanets.de/
in IC Capture 2.3 and FireCapture you have the option to enable trigger mode
the hardware and trigger
i use a hall sensor and i have a magnet glued inside the projector on the wheel so every time the wheel rotate and comes near the hall sensor it output 5v to the camera trigger
here is a picture of the wheel and hall sensor
here you can see the whole trigger cabel with hall sensor
here is a better picture of the hall sensor
here is the wiring diagram to build the trigger and i did copy it from here http://www.cine2digits.co.uk/
#4 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 29 December 2013 - 11:05 AM
So cool! Thanks for posting all the pictures. I was using a physical lever switch to trigger my scanner before, but I was planning to try out a light sensor with laser or led setup for the next version. The hall sensor is cool though, I might have to think about that.
#5 Mattias Norberg
Mattias Norberg
  • 24 posts
Posted 29 December 2013 - 03:34 PM
i have seen this video that they use laser sensor called sensopart PS-L4 i think
i did see in some other picture he have placed the laser sensor diagonally i guess it´s because for example let's say if you look out of a window and you stand much more on the other side of the window then the window is not so wide anymore :)
so i guess it get´s more accurate for the sensor to detect sprocket hole if the laser sensor hits the sprocket hole diagonally
Edited by Mattias Norberg , 29 December 2013 - 03:36 PM.
#6 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 30 December 2013 - 07:01 PM
Yeah, the Muller was pretty much my inspiration from the beginning; the thing's a work of art! So that's why the laser was in my head. I got this of Amazon for $8 the other day, so I'll give that a shot. I'm not exactly sure if I'll use a laser and shoot it through a perf, or just mount it behind the shutter to let me know when the shutter's clear. I'll see once my new projector gets here. Fun to play with though!
Edited by Josh Gladstone, 30 December 2013 - 07:02 PM.
#7 Mattias Norberg
Mattias Norberg
  • 24 posts
Posted 31 December 2013 - 05:44 AM
i have been thinking my self to buy a Arduino or Raspberry Pi and a stepper motor and see how it all works
the light sensor you did link was compatible with arduino :)
#8 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 31 December 2013 - 09:43 AM
That's exactly what I did. Arduino+stepper motor. The arduino is so cool. Now I have it running the motor, the LEDs, the trigger, etc. I definitely encourage you to get one. And I had never used one before or programmed anything like that before, so its definitely doable. And it was actually a lot of fun and really rewarding getting that thing working.
#9 Phil Rhodes
  • 12171 posts
Posted 31 December 2013 - 11:57 AM
Lots of things are described as "compatible with arduino" - all that really means is that it's a 5V logic device.
  • 1
#10 Mattias Norberg
Mattias Norberg
  • 24 posts
Posted 01 January 2014 - 01:20 PM
ok sound good i guess i have to buy one :)
Phil ok then i know
  • 1
