Wiring Diagram for Original Bolex Power Connector
#1 Robert Ditto
Robert Ditto
  • 72 posts
Posted 09 January 2014 - 07:43 PM
Good Evening Everyone.
I was wondering if any of you Bolex Tinkerers out there could help me with a project I am working on?
I have a very good 12v DC battery and I would like to build a power connector box that would have both a 4-pin XLR connector to run my Tobin Motor and an original Bolex connector to run my EBM.
Or I can just have the XLR but will need to make an XLR to original Bolex power cord. Either way is fine with me, I just need to know how to wire it correctly. I dont want to ruin any of my equipment.
Sincerely, Respectfully,
Robert M. Ditto
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 762 posts
  • Montreal, Canada
Posted 13 January 2014 - 12:23 PM
Hi Robert,
The wiring will be different depending on whether you're going straight into the camera body or if you're going through the power grip or flat base adapter. What do you have?
Jean-Louis
#3 Robert Ditto
Robert Ditto
  • 72 posts
Posted 13 January 2014 - 07:28 PM
Hello Jean-Louis!
I have the hand grip but dont use it. Would rather get rid of it actually. I do have rhe flat base adapter that I use when not shooting crystal sync. I also have the Tobin Crystal controller for shooting sync sound.
If I need three power out puts for all three of the different connections, that is fine with me. But I would like to run a single connection to the box from the battery, then break it out into different sockets connections for the different connectors on the motors/controllers.
Thank You!
Robert M. Ditto
#4 Jean-Louis Seguin
Jean-Louis Seguin
  • 762 posts
  • Montreal, Canada
Posted 14 January 2014 - 01:11 PM
Hello Jean-Louis!
Thank You!
Robert M. Ditto
If you're using the flat base, I can make you a cable to plug into it. Contact me off the board.
Jean-Louis
