Changing power plugs on universal ballasts?
#1 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 30 January 2014 - 05:34 AM
Hi guys,
I've found a used Arri HMI from the States that I'd like to buy, it has a standard US power plug, but the ballast is universal, so should be fine for the 230v power down here in Australia.
I can't see any kind of switch on the ballast to select between 120v and 230v power, so I'm wondering whether simply changing out the US plug for a local one, or using a simple adapter will be all I need to do to use the ballast?
Does anyone know if there a particular process required to 'switch' the ballasts to use 230v power, or are they simply okay with being plugged into either voltage?
Cheers,
Mark
#2 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 30 January 2014 - 02:58 PM
The ballasts are Auto-Voltage sensing: just change the plug
The cores in the main cable are coloured in accordance with following code:
Earth: green/yellow
Neutral: blue
Live (Phase) : brown
#3 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 31 January 2014 - 02:00 AM
Thanks Edward, much appreciated.
