Battery help for Arri 2c crystal motor
#1 Callum Ross Thomson
Callum Ross Thomson
  • 8 posts
Posted 06 February 2014 - 09:19 PM
I have recently ordered a CP crystal 24fps motor for my new (or should I say old) 2c.
In my hunt for a battery locally, and it's been suggested to me by a hobby store that
I could use a 14.8v LiPo battery as they're much smaller, lighter, run at a more constant
speed and hold much more power than the NiMH batteries that most people seem to
use with their arri motors.
I was originally told by the seller that this motor needs 16-18v, that if I use 12v it
won't maintain crystal sync speed. My understanding from reading on this forum
is that pretty much all constant speed 2c motors actually only need 12v, but if you
use a 12v battery the voltage can/will drop below 12v occassionally, so you need
a battery higher than 12v as a sort of safety net.
I haven't been able to get in contact with the seller of the motor since i've made the
purchase, so my question for you bright folk here is: do you think a 14.8v would allow
enough of a margin to maintain crystal sync speed for this motor?
Thanks in advance for any help!
Edited by Callum Ross Thomson, 06 February 2014 - 09:21 PM.
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 754 posts
  • Montreal, Canada
Posted 07 February 2014 - 08:47 AM
Are you sure this motor requires 16-18V ?
If the power connector is a 4-pin XLR, there are good chances the motor requires 12V only.
In that case a 14.8V battery should work fine.
You'll probably need a capacity of at least 5A to get a decent running time.
Jean-Louis
#3 Callum Ross Thomson
Callum Ross Thomson
  • 8 posts
Posted 18 February 2014 - 08:02 AM
Thanks Jean, I hoped that was the case. That's the thing, the seller said it needed 16-18v, but maybe he meant
to imply that it just can't run on 12v. I've gone ahead with the 14.8v LiPo battery, it's 4.4A, hopefully that'll be sufficient -
unfortunately I can't see myself having the pleasant problem of having enough film to run a battery out first.
I've just got to figure out how to solder these beefy battery wires to a new little 4 pin XLR connector and i'll be
able to confirm if it works alright.
Callum
#4 Callum Ross Thomson
Callum Ross Thomson
  • 8 posts
Posted 19 February 2014 - 06:47 AM
I wired up the battery tonight and it works perfectly. Not sure on total run time once it's fully charged, but
in terms of size i'd definitely recommend LiPo batteries for these older cameras. It's small enough
to velcro onto the side of the motor base.
