Traveling With Film ->
#1 Nealesk
Nealesk
  • 10 posts
Posted 08 February 2014 - 01:03 PM
Hi, new member here. I asked a question over in the 16mm forum about purchasing a camera and got incredible responses so I thought I'd ask another perplexing question.
I'll be traveling to Cambodia, Kenya & Ecuador this summer to make my newest film. I will probably take 1000-2000 feet of film in 100 foot spools.
So my question, how does traveling with film work? Don't you have to get everything X-Rayed when you travel by plane? What is the best way to approach shooting film when traveling to different countries??
Any ideas are much appreciated!
#2 Gregg MacPherson
Gregg MacPherson
  • 1966 posts
  • New Zealand
Posted 08 February 2014 - 03:06 PM
There have been one or two threads on the Xray issue.  If you find one you could resurect that.
Cheers.
  • 1
#3 Heikki Repo
Heikki Repo
  • 423 posts
  • Finland
Posted 08 February 2014 - 03:59 PM
You can travel with film but NEVER put it in the checked luggage (= luggage that goes in to the cargo hold). Those x-ray scanners are powerful and will almost definately ruin your film. Hand luggage -- the luggage you can take with you when boarding the plane -- should be safe as those x-ray scanners are usually much weaker.
Kodak suggest their film material should never be x-rayed. Unfortunately that isn't always possible. However, if you follow the guideline mentioned above you should be safe in most cases.
#4 Kip Kubin
Kip Kubin
  • 131 posts
Posted 14 February 2014 - 11:27 PM
TSA will hand check film if you ask.
Always ask.
#5 Adrian Sierkowski
  • 7488 posts
Posted 15 February 2014 - 12:04 AM
Ask for a hand check of film-- and keep a changing bag with you as well.
Also investigate if you can buy stock in country-- or have it shipped to your hotel/place you're staying.
Never check film-- always carry on.
Minimize the amount of times it goes through X Ray
Once exposed, see if you can ship it out of the country for processing-- or if there is a lab near you (check with Kodak they keep a list).
Also the slower the stock the less you have to worry about.
DO NOT PUT IT IN LEAD LINED OR X RAY PROOF THINGS-- This will only mean they will turn up the power on their scanners.
#6 pierre robichaud
pierre robichaud
  • 10 posts
Posted 16 February 2014 - 06:11 PM
I've found drastic inconsistencies with this. One airport will allow you to pass and others will not let you through. I stated the hand check policy and was told by a TSA agent, " I'm not sticking my hand in there. I don't know what you could have in it." I had to stay behind in Newark to go to the nearest FedEx station and have all of our negative sent that way. Most TSA security X-rays state that anything below 800ASA is safe, but as with all other TSA statements I'd take it with a grain of salt. Bottom line is, as others have suggested, be prepared to have it sent out of country prior to your departure.
good luck!
