Standard 16mm film stock
15 replies to this topic
#1 Simon Glidewell
Simon Glidewell
  • 7 posts
Posted 15 February 2014 - 10:20 AM
Does anyone know a good source in Europe to obtain standard 16mm film stock, colour and black and white? Also, is standard 16 B&W reversal stock still available and does anyone process it nowadays? I presume there are labs in Europe who will transfer film to a digital format for editing in FCP?
Simon
#2 Freya Black
Freya Black
  • 4164 posts
Posted 15 February 2014 - 10:43 AM
Simon
I'm not sure what you mean by standard 16mm stock. Do you mean 2perf, as that tends to be a special order type thing?
If you mean just for a standard 16mm camera, then most of them take single perf which is more easily available.
The only B&W 16mm reversal left is Tri-X.
Freya
#3 Freya Black
Freya Black
  • 4164 posts
Posted 15 February 2014 - 10:45 AM
Freya
Actually I think I'm lying. That's the only Kodak B&W reversal stock left. There is also Fomapan, and maybe Orwo do a B&W reversal?
Freya
#4 Simon Glidewell
Simon Glidewell
  • 7 posts
Posted 15 February 2014 - 11:02 AM
I mean standard 16mm (like standard 8mm) as opposed to super 16, with the aspect ratio of 4:3 instead of 16:9. That was the name given to the stock once super 16 was introduced. As far as I know standard 16mm can be either single or double perf.
Simon
Edited by Simon Glidewell, 15 February 2014 - 11:05 AM.
#5 David Cunningham
David Cunningham
  • 1054 posts
Posted 15 February 2014 - 12:02 PM
Any single perf 16mm film can be used in either a standard or super16 camera. Even double perf can be used in either camera, but the perfs will interfere with the right side of the super16 frame. The film size, perf size and perf pitch are the same for all 16mm camera film.
There is a small set of very old 16mm cameras that require 2perf 16mm which is generally hard to find these days.
#6 Adrian Sierkowski
  • 7375 posts
aspect ratio of the film is determined by the camera. S16mm and 16mm both use the same film
The only difference is whether the film is 1R or 2R-- this has to do with it's perforations-- either 1 perforation down one side (the most common) or 2--one on each side (special order).
Whether you need 1R or 2R film will also be dictated by your camera. Almost every modern camera is a 1R camera.
  • 1
#7 Simon Glidewell
Simon Glidewell
  • 7 posts
Posted 15 February 2014 - 12:58 PM
Thanks for all your kind responses, but this does not answer my original question apart from the reversal film part of it...
Cheers
Simon
#8 David Cunningham
David Cunningham
  • 1054 posts
Posted 15 February 2014 - 01:14 PM
http://www.wittner-k...nik.de/home.php
Wittner is probably your best source of all kinds of motion picture film in Europe.  They even have some 2R (2 perf) films and DS8 (Double Super 8).
  • 1
#9 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 15 February 2014 - 01:54 PM
Simon
The name never changed because the stock didn't. You just had to avoid double-perf. Super-8 had a smaller perforation in a different place. The only common parameter with 8mm. was the width of the film.
In fact I came unstuck on a student film shot in 1.66 soft matte widescreen on 4:3 when I specified single-perf '47 and we had to pay for an optical when the editor (oh, hang on, that was me as well) wanted to flop a shot. With double-perf the shot could just have been reversed in the neg cut, at the cost of a bit of sharpness. So we got our money's worth by having a freeze frame as well.
Edited by Mark Dunn, 15 February 2014 - 01:55 PM.
  • 1
#10 Heikki Repo
Heikki Repo
  • 421 posts
  • Finland
Posted 15 February 2014 - 02:20 PM
Wittner is good for reversal film but if one is looking for negative film stocks for gauges wider than super-8 -- not really.
If you are located in UK you can buy Kodak film here http://take2films.co...ores/filmstock/ and cheap Fuji 16mm stock is available here http://filmstockclearance.com/
Edited by Heikki Repo, 15 February 2014 - 02:21 PM.
  • 1
#11 David Cunningham
David Cunningham
  • 1054 posts
Posted 15 February 2014 - 03:13 PM
Good call on take2films and filmstockclearance. If you were here in the USA, direct from Kodak is the best negative option.
  • 1
#12 Dirk DeJonghe
Dirk DeJonghe
  • 612 posts
  • Kortrijk,Belgium
Posted 15 February 2014 - 03:55 PM
Nowadays most people use negative stock (colour or B&W). It can be transfered to digital HD format with very good results. Reversal film is only suitable for direct projection, but has much less exposure latitude.
Also, you can still make very good projection prints from negatives, while making prints from reversal requires an expensive internegative since no reversal print film is available any more.
  • 1
#13 Randy J Tomlinson
Randy J Tomlinson
  • 125 posts
  • USA / Europe
Posted 15 February 2014 - 06:16 PM
http://www.filmstockclearance.com/
good source in england. if you order from there say hi from randy tomlinson to rachel baker. im a regular customer (35mm)
  • 1
#14 Chris Burke
Chris Burke
  • 1726 posts
  • Boston, MA
Posted 16 February 2014 - 07:04 AM
Orwo UN54 can be processed as negative or positive. They are a German company, no, and I am assuming available in Europe.
  • 1
#15 Simon Glidewell
Simon Glidewell
  • 7 posts
Posted 16 February 2014 - 02:57 PM
Many thanks everyone for your very helpful posts; much appreciated! I shall look into these now.
All the best
Simon
#16 Heikki Repo
Heikki Repo
  • 421 posts
  • Finland
Posted 28 April 2014 - 11:52 AM
I just have to add this -- Frame24 (filmstockclearance.com) is now selling Kodak stocks as well! The price is really good also!
http://www.frame24ltd.co.uk/
