odd sandbagging
sandbagging an odd stand
15 replies to this topic
#1 JB Earl
JB Earl
  • 147 posts
  • NE PA USA
Posted 19 February 2014 - 11:53 AM
Does anyone know the proper way to sandbag a stand like this?
Edited by JB Earl, 19 February 2014 - 11:54 AM.
#2 Will Barber
Will Barber
  • 107 posts
  • NYC
Posted 19 February 2014 - 12:04 PM
Fold it in half around the center post inside the legs.
I usually do it so it's resting on two of the supports.
Edited by Will Barber, 19 February 2014 - 12:04 PM.
#3 Toby Orzano
Toby Orzano
  • 80 posts
  • Electrician
  • Portland, OR
Posted 21 February 2014 - 04:16 AM
Personally I would tie the sandbag tightly to the stand, take the whole rig to a bridge and throw it off into the water, then get a real stand.  :lol:
#4 Tad Kenneth Howard
Tad Kenneth Howard
  • 2 posts
Posted 21 February 2014 - 12:03 PM
Yes, I do and so do several of my co-workers.
#5 JB Earl
JB Earl
  • 147 posts
  • NE PA USA
Posted 27 February 2014 - 07:36 AM
Toby, sorry I don't get it.  What's wrong with this kind of stand?
#6 Will Barber
Will Barber
  • 107 posts
  • NYC
Posted 27 February 2014 - 11:51 AM
I think it just is a cheap stand with what looks like a pretty large mount at the top. I would probably avoid putting heavy lights on a stand like that.
#7 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 27 February 2014 - 12:36 PM
It is a Photo stand made by Manfrotto: extended 13lbs capacity , collapsed 55lbs capacity. Retails for about $250.00 USD :0
#8 Gregg MacPherson
Gregg MacPherson
  • 1933 posts
  • New Zealand
Posted 27 February 2014 - 03:36 PM
Maybe TobyTad (tied together by now and about to be marched to the railing) could just tell him what's bad about the stand.
#9 Jeff Wolfram
Jeff Wolfram
  • 8 posts
  • Grip
  • DC
Posted 27 February 2014 - 05:57 PM
I am sure the comments were just said in jest we're all friends here.
I can't tell from the small pic if the stand is Bogen's heavy duty "wind up" but if not from the picture you can see that the center stays are fully extended yet the angle of the legs outward is only at  45 degrees making the stands overall footprint to be rather small (narrow) going back to the idea if you need to sand bag this stand due to iffy circumstances maybe it is best to choose a stand for that specific application that does have a much wider footprint before thinking that the sand bags are going to do all the stability.
just my thoughts looking from a small laptop screen
#10 JB Earl
JB Earl
  • 147 posts
  • NE PA USA
Posted 27 February 2014 - 06:11 PM
It's a manfrotto 111u, tall steel cine stand. (not the wind up). it's about 12' high, and 5' when folded.    It does have a slightly smaller footprint than a combo or high roller. I think 42"
I have other big stands, just got a good deal on this and never used one with the high braced legs.
#11 JB Earl
JB Earl
  • 147 posts
  • NE PA USA
Posted 27 February 2014 - 06:17 PM
btw, anyone know what the little loophole in the top casting is for?  You're not supposed to tether stands, right?
#12 Jeff Wolfram
Jeff Wolfram
  • 8 posts
  • Grip
  • DC
Posted 27 February 2014 - 09:05 PM
oh that's for staircases and as soon as you set it up someone is going to want to use the staircase. Sure they'll say they're just going to sneak by without bumping it...  right.  My answer to your orginial question the proper way is to over, over, sandbag it.  Like you say it's a narrow footprint that normally needs to be extended to a high height (on a slope) and someone is going want to squeeze past it.
If the stand is on a hillside and the adjustable leg still doesn't get the stand to sit with the weight perfectly underneith the stand the loophole can be used with a safety guideline to a stake (at least that's what we have used it for in the past)
#13 andrew ward
andrew ward
  • 269 posts
Posted 01 March 2014 - 05:00 AM
Hang it on the lockoffs.
Loophole is so you can tie it off so your fleckie dont blow over.
Put it on some sushis to get a little bit of space so the bags can hang over leg struts if youre worried.
If you were mega worried, ratchet a bag around the leg.
Or get a facebook friend to hold it.
Or HIRE A GRIP and let them worry about it.
#14 Toby Orzano
Toby Orzano
  • 80 posts
  • Electrician
  • Portland, OR
Posted 05 March 2014 - 12:20 PM
One big objection is to the ground-level spreader. PITA to open and close, and it bones you if you were trying to put multiple of these close together, you can't nest the legs like normal combis and beefy babies. And with a 13 lb capacity you can't even mount an ARRI 1200 or M18, so a junior receiver is kind of pointless. Heck, as per the Mole website, a 1K baby weighs 13.75lbs.
I really was kidding though, you use what you've got available. No offense intended.
#15 JB Earl
JB Earl
  • 147 posts
  • NE PA USA
Posted 05 March 2014 - 12:30 PM
Thanks everyone.  BTW the 13 lb capacity is only for when it's at a lean, normal capacity is 55 lbs.
http://www.manfrotto...-w-leveling-leg
#16 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
  • Anywhere they pay me to go
Posted 11 March 2014 - 02:24 AM
Make do with what you've got. I am not a big fan of these but  they are not that bad.
As Toby say's, they can't be nested very easily, but otherwise they are fine. I had a bunch of these handed to me - Avenger, I think, on a feature film in Rome. They can handle quite a lot of weight - more than I expected. The Avenger C-stands are great btw.
