Super 8 or Super16 Newbie alert!
vintage movie camera
16 replies to this topic
#1 Lyn Ciampa
Lyn Ciampa
  • 14 posts
Posted 23 February 2014 - 03:53 PM
I have decided to enter the realm of film.
I am a horticulturist/landscaper and  I will be shooting plants and landscapes (no further than a 'street scene')
SO,  I would like:
single frame/cable release cabability
Electronic
Stellar resolution and durability (In case it falls off a mini tripod when shooting a rock or leaf- I don't want the camera to shatter into a million pieces. Also I live in wyoming and the wind blows something fierce so it can't be a dust magnet)
approx 100.00 for a camera lenses and lens caps
I decided against 8mm because the 11sec/roll of film would drive me nuts
it seems that for:
resolution and detail I would want a 16mm
for portability I would want an 8mm
What i've read so far recommend Bolex and Canon
Any thoughts?
Thanbks
#2 Adrian Sierkowski
  • 7488 posts
Posted 23 February 2014 - 06:10 PM
I think for what you're doing you'd want a stills camera which has a timelapse mode-- but you're not going to find much of anything for $100.
#3 Lyn Ciampa
Lyn Ciampa
  • 14 posts
Posted 23 February 2014 - 06:40 PM
Thanks for the quick reply
I already have a still camera.
I install water features so I will be filming those, I also would like to use the video for shooting animals and such in the landscapes and I am looking for that 1970's home movie film look
#4 Dan Dorland
Dan Dorland
  • 38 posts
  • Minneapolis
Posted 23 February 2014 - 07:28 PM
For the 16mm option I'd recommend a Krasnogorsk-3. It has single frame shooting, and a body + the usual 17-69mm lens can definitely be found for $100 on eBay, and sometimes on craigslist. However for the 70's home movie look, go no further than a Super 8mm camera. Film stocks nowadays are so good, that it would be very hard to get a home movie look from 16mm IMO. Even Super 8 can look too good with the right scan.
it seems that for:
  • 1
#5 Adrian Sierkowski
  • 7488 posts
Posted 23 February 2014 - 07:35 PM
K3 is a good choice; but doesn't allow for timelapse. I don't know if it has a cable release, and certainly isn't electronic.
#6 Lyn Ciampa
Lyn Ciampa
  • 14 posts
Posted 23 February 2014 - 08:23 PM
I'm looking at these
http://www.ebay.com/...=STRK:MEBIDX:IT
Bauer C 107 XL Super 8 Movie Camera Macro Neovaron 7-45mm 1:1.2
(I am told Bauer's excel in low light)
Beaulieu 2008 Super 8MM Camera w/Angenieux 8-64MM. f/1.9 Zoom Lens
and here is the only K3 I found (on Ebay, that is) is it a good one?
KRASNOGORSK-3 16mm AMATEUR CINE CAMARA
http://www.ebay.com/...=item2ecf0bf2fa
Lyn
Edited by Lyn Ciampa, 23 February 2014 - 08:26 PM.
#7 Dan Dorland
Dan Dorland
  • 38 posts
  • Minneapolis
Posted 24 February 2014 - 10:56 AM
Well, it does allow for timelapse if you either buy a separate motor to do it like this one: http://www.k3camera....-time-lapse.php
or stand there for hours with the cable release, but that is very impractical.
  • 1
#8 Will Montgomery
Will Montgomery
  • 2106 posts
  • Dallas, TX
Posted 25 February 2014 - 10:10 AM
It has a cable release but not sure about single frame. The cable screws into the "on" button in the front. Allows you to put it on a tripod and use the cable release to run it so you don't shake the camera.
#9 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 25 February 2014 - 12:39 PM
The cable release socket on the front of the trigger button allows you to 'run' the camera with a release.  Opposite this on the rear of the camera is another release socket that triggers single-frame exposure.
Although it worked on my camera, I have read that it can be very stiff or even seized on some.  I also understand the exposure can be a bit variable as the clockwork spring unwinds.
#10 Lyn Ciampa
Lyn Ciampa
  • 14 posts
Posted 25 February 2014 - 01:07 PM
I am leaning towards 16mm as the film prices and processing seem to be comparable to S8 anyway and 16mm offers better resolution.
the K3 looks like a good bet, and I am also looking at these:
Eumig C16
http://r.ebay.com/pBWnAX
Beaulieu 2008
http://r.ebay.com/8Opr6Z
Bauer C 107 XL (8mm, but I am told that 'XL' in camera model numbers indicate low light capabilities. Is this correct?)
http://r.ebay.com/FxW4iE
Bolex (I like the side mounted viewfinder)
http://r.ebay.com/36iOuo
#11 Gregg MacPherson
Gregg MacPherson
  • 1966 posts
  • New Zealand
Posted 25 February 2014 - 02:10 PM
Some early Bolex cameras were non reflex.  The top finder views through the top lens then you have to rack that lens over to the shooting position.  The side finders are not reflex.  I found this type a pain in the ass.
#12 Dom Jaeger
Dom Jaeger
  • 1817 posts
  • Melbourne, Australia
Posted 25 February 2014 - 08:06 PM
$100 won't get you much in 16mm if you want a decent lens as well as a camera. That Bolex is ancient, from the 40s, and only takes double perf film which is special order these days. The chances of it working perfectly are about as good as the chances of a 1940s car still driving well after decades in a garage.
You might find a K3 that cheap, and it might work OK, but they're not really suitable for single frame - the shutter is an angled mirror which will leak light through to the film if you spend too long between shots without capping the lens. The best film cameras for single frame animation or timelapse are ones that use a focal plane shutter (that sits flush over the gate) which is better at preventing light from leaking around to the film. Bolexes were often used for animation because of this, but a newer, reflex model with prime lenses or a zoom will cost at least several hundred dollars. If you don't want to manually trigger a timelapse sequence (very likely) you'd also need a timelapse motor for a Bolex, which can easily be several hundred dollars more.
Your budget is better suited to a Super 8 camera, maybe one of those Nizos that has a built-in intervalometer for timelapse.
#13 Lyn Ciampa
Lyn Ciampa
  • 14 posts
Posted 25 February 2014 - 08:08 PM
The Eumig link was bad. This one should work:
http://r.ebay.com/1MIRe7
How about this Nizo:
http://r.ebay.com/YKNtTG
Edited by Lyn Ciampa, 25 February 2014 - 08:12 PM.
#14 David Cunningham
David Cunningham
  • 1054 posts
Posted 25 February 2014 - 08:49 PM
Take it from someone who has tried all the super cheap cameras. You'll just find yourself frustrated and disappointed. You really need to be willing to spend $400 or more and get something with a decent reflex viewfinder and lens.
Non reflex and/or bad (small and dark) reflex are just too frustrating to use. Don't bother with anything below a Rex4 or you'll go blind trying to pull or guess focus.
#15 Lyn Ciampa
Lyn Ciampa
  • 14 posts
Posted 25 February 2014 - 09:06 PM
It looks like I need to go up to 200$.
#16 Lyn Ciampa
Lyn Ciampa
  • 14 posts
Posted 25 February 2014 - 09:13 PM
400 is too much. If I wait I a week could go up to 280$. I will add a Reflex viewfinder to what I will need.
So far it's
16mm (preferred- because of the better resolution Is this correct?
Reflex viewfinder
Single frame/cable release capable
proficient in Low light
not dust sensitive
#17 Adrian Sierkowski
  • 7488 posts
Posted 26 February 2014 - 02:43 AM
Film resolution is an iffy thing. It's not really like a digital sensor. While 16mm may have higher resolution if you're comparing a 50D in that and 8mm, a 500T 16mm will probably have much worse than a 50D in 8mm-- it all depend. What you're really talking about is granularity-- e.g. how large the grain is on the film, and that too is a function not only of the stock, but it's age, handling, and development as well as the ratio of enlargement (8mm might look better on an iphone than say 16mm on the big screen).
That all said, yes you're likely to be looking at 16mm, and I would highly recommend getting a good camera-- hold off on buying it for a bit, prices are always coming down, and they aren't going anywhere. Plus ANY camera you get will need to be serviced, or at least looked over, which will add a few hundred to the cost before you even go out and buy/process and transfer your first foot of film.
I'm not sure, as I haven't checked recently, but I would wager, 16mm is cheaper per foot overall than 8mm since there are more labs which deal with it-- especially for high quality HD scanning.
Also every film camera is to a certain extent dust sensitive-- and also hair and film crap sensitive. On the bigger badder cameras we often pull the lens off after a set up and check to make sure there's no schmutz in the gate before we move on. I can pretty much guarantee on an 8mm or a clockwork 16mm camera you'll have schmutz in the gate it's part and parcel of how they are generally handled/loaded/film packed ect.
