Please what is the name of this effect called and how can it be done
#1 John1
John1
  • 46 posts
Posted 28 February 2014 - 06:53 AM
I see this effect in very many music videos and it makes them kinda look cool and professional. This light streaks usually, red, pink, purple used for transitioning between one cut to another. I know its not lens flare. Please check out this music video. You will see it. I want to know the name and how its done. That light streak is continuously used in transitioning
Edited by John1, 28 February 2014 - 06:54 AM.
#2 Heri Rakotomalala
Heri Rakotomalala
  • 13 posts
  • Montreal, Canada
Posted 28 February 2014 - 07:38 AM
I just call them light streaks
These are done in post - It's available as stock footage, with a transparent layer, and just add it on top on your edit software.
Here's a stock site having them.
#3 Freya Black
Freya Black
  • 4164 posts
Posted 28 February 2014 - 08:10 AM
These look like flash frames to me.
Traditionally these would usually be orange actually but what the hey! :)
This is usually done in post these days as Heri says but used to be an effect of shooting on film, especially on Super8 cameras when someone would open the cart door and let light in or swap cartridges etc etc. It's the effect of light getting in at the emulsion.
Freya
Edited by Freya Black, 28 February 2014 - 08:12 AM.
#4 Freya Black
Freya Black
  • 4164 posts
Posted 28 February 2014 - 08:14 AM
Just to add, the reason it is getting used as a transition is that usually it was something that happened between scenes for various reasons. (such as swapping carts as I said earlier)
You will notice that it is often at the edges of the frames as this is the light getting in at the edges of the emulsion.
Freya
#5 John1
John1
  • 46 posts
Posted 01 March 2014 - 09:40 AM
#6 Brian Drysdale
  • 5197 posts
Posted 01 March 2014 - 12:08 PM
It's something you also get at the beginning and the end of daylight loading spools as found on 16mm Bolex cameras or Regular 8mm cameras. Some of these also have small holes perforated in the end of the leader as an additional effect. These reels have leader at either end, which you don't use and ideally you load the camera in a darkened place, to avoid this, but the real world does step in, so you get this flashing effect.
#7 Freya Black
Freya Black
  • 4164 posts
Posted 01 March 2014 - 01:21 PM
At one stage I was trying to make a film that consisted entirely of those little holes and flashes but I couldn't get enough of them together! :)
The movie "Vampyr" by Dreyer also features those holes (he was a bit stuck for filmstock when he made that film!)
Freya
