De Flicker plugin for FCP
7 replies to this topic
#1 Stuart Brereton
Stuart Brereton
  • 3346 posts
Posted 28 February 2014 - 01:20 PM
Any recommendation for a cheap (read free) way to De Flicker a clip in FCP. I have a roughly 4 second shot which has some bad fluorescent flicker on it which I need to try and fix urgently.
#2 Phil Rhodes
  • 12167 posts
Posted 28 February 2014 - 01:59 PM
Super coarse free solution
If you can run VirtualDub either on a windows machine or under a virtual machine, there is a reasonable deflicker filter here:
http://neuron2.net/deflick/flick.html
Demo
The material will need to be an AVI to go into VirtualDub - there are ways to avoid it but if it's short just spit it out as an AVI.
#3 Michael Kubaszak
Michael Kubaszak
  • 207 posts
  • Chicago
Posted 28 February 2014 - 02:58 PM
This has helped me in the past.
http://www.larryjord...ips/tip356.html
#4 Stuart Brereton
Stuart Brereton
  • 3346 posts
Posted 28 February 2014 - 07:33 PM
I managed to fix it myself. It was 60hz flicker from an overhead fluorescent, which I thought I had dealt with by going to 1/30 shutter (this was a dSLR shoot). The flicker vanished on my 7" monitor , but was very evident watching dailies.
Looking at it frame by frame, it seemed to just be alternate frames of light and dark, so I laid an identical clip over the top of it in FCP, offset by one frame, and then changed layer composite mode to Darken. This solved the problem completely.
Thanks for the suggestions.
  • 1
#5 Phil Rhodes
  • 12167 posts
Posted 28 February 2014 - 08:58 PM
I have acres of FS700 footage shot at 100fps under 50Hz light which simply needed every other frame dropping. And you get two choices as to how bright you want the light to look!
What monitor was it? It shouldn't hide that sort of thing.
#6 Freya Black
Freya Black
  • 4164 posts
Posted 01 March 2014 - 01:25 PM
er, shouldn't 100fps be safe under 50Hz or were you dealing with some very nasty lighting?
Freya
#7 Phil Rhodes
  • 12167 posts
Posted 01 March 2014 - 01:51 PM
Of course not! Flicker-free ArriSuns all the way.
Oh, no, wait, this is London, isn't it.
#8 Freya Black
Freya Black
  • 4164 posts
Posted 01 March 2014 - 02:01 PM
*giggle* Of course!
Sorry I asked! :)
I'm a fan of Solar lighting!
Freya
