Projecting vertical
super 8 vertical projection
11 replies to this topic
#1 Francesco Palombi
Francesco Palombi
  • 13 posts
Posted 11 March 2014 - 06:25 PM
Hi everyone,
I do mostly photography and for an installation I'm planning to project some super 8 videos i'm planning to shoot.
My question is, can I project them vertically?
I don't have a super 8 projector and I've never used it, so I've no idea if that can be challenging.
Francesco
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 12 March 2014 - 08:40 AM
The projector should be kept in the normal position and use a mirror mounted at 45 degrees to project upwards.
Jean-Louis
#3 Francesco Palombi
Francesco Palombi
  • 13 posts
Posted 12 March 2014 - 08:58 AM
Hi Jean-Louis,
my bad. English is not my first language. For vertically I meant "portrait format" oriented video.
Does it make sense?
Francesco
#4 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 12 March 2014 - 01:04 PM
I suppose you could do it with the projector laying down on its left side.
As long as do not block the air circulation to the ventilator grill.
Jean-Louis
#5 Joerg Polzfusz
Joerg Polzfusz
  • 123 posts
Posted 12 March 2014 - 02:30 PM
Does it make sense?
Hi!
I understand what you want to do. But it doesn't make any sense to me as Super8 is 1:1.33 and hence nearly square. So it wouldn't make any great difference whether you project this way or another...
#6 Andries Molenaar
Andries Molenaar
  • 683 posts
  • Amsterdam
Posted 12 March 2014 - 03:19 PM
Use two (surface) mirrors, project on one and onto the other, rotate them both a part of total 90 degrees for portrait and of course make them project on the screen ahead.
#7 Andries Molenaar
Andries Molenaar
  • 683 posts
  • Amsterdam
Posted 12 March 2014 - 03:21 PM
Hi!
Or mask off the sides. A sideway letterbox :)
#8 Roberto Pirodda
Roberto Pirodda
  • 112 posts
  • Italy
Posted 14 March 2014 - 02:01 PM
if i have understand correctly what you want to do, you must shoot with your camera rotated by 90 degrees, otherwise you will get vertical horizon-landscape
  • 1
#9 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 14 March 2014 - 02:34 PM
You can't rotate a projected image with flat mirrors alone, only reverse it.
Edited by Mark Dunn, 14 March 2014 - 02:35 PM.
#10 Dom Jaeger
Dom Jaeger
  • 1734 posts
  • Melbourne, Australia
Posted 14 March 2014 - 06:39 PM
True, for rotation you need to use something like a Dove prism:
http://en.wikipedia....wiki/Dove_prism
But as Joerg mentioned, the nearly square S8 frame turned sideways is hardly portrait. A fairly simple method to get a more vertical projection aspect ratio is to shoot and then project with a 2X anamorphic lens turned 90 degrees (so that it compresses and later uncompresses vertically). This is what Tacita Dean did for her marvellous Tate installation. A 4:3 horizontal frame would become a 4:6 vertical one, some masking of the sides could make it more portrait still.
Or simply mask a normal frame, but you'd lose a lot of image area.
For an installation that may be running for a while I don't think turning a projector sideways would be a good idea.
#11 Francesco Palombi
Francesco Palombi
  • 13 posts
Posted 16 March 2014 - 01:17 PM
Thanks everyone.
Coming from photography the Super 8 frame turned, for me make kind of a big difference. Just look at 4x5 photography, vertical and horizontal pics.
Mmm anyway this sounds tricky..the use of a prism i guess would bring too much attention to the viewer, unless I can kind of hide that.
The tape I guess I just have to give it a try and see how it looks.
F
#12 Joerg Polzfusz
Joerg Polzfusz
  • 123 posts
Posted 17 March 2014 - 06:06 AM
IMHO the main problem would be the heat:
Normally the hot gets blown out of the projector to its left side and then floats up:
However when the projector gets rotated, the hot air gets blown out to the bottom and then returns:
This shouldn't cause a problem when projecting a single reel. However when you do this in an "endless loop" for an installation, I fear that the projector and the film might get too hot.
