See the beam of light
#1 AlejandroGomez
AlejandroGomez
  • 56 posts
  • 2nd Assistant Camera
  • Germany
Posted 23 March 2014 - 12:44 PM
Hi!
I'm trying to get a light setup like this :
I know that when you use a backlight this reveals the trajectory of the light, because the particles in suspension reflect this same light. So  I ask my self what kind of light projector I will need.
Do I need a more spot light or flood light? And it's necessary only 1 light without any other light in the room? It's possible to get this look with natural source of light?
I only have 3 500W halogen projectors, it possible to get this light with these projectors?
If I have the possibility to rent light projectors, what kind of this I will need and reflectors (parabolic, elipsoidal...) ?
Thank you all
#2 Dan Dorland
Dan Dorland
  • 38 posts
  • Minneapolis
Posted 23 March 2014 - 11:28 PM
There's probably more to it, but I'm sure using a fog machine to give the space just a little bit of atmosphere would go a long way in making the light visible.
#3 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 24 March 2014 - 03:53 AM
What kind of halogen lights do you have? Are they 500w worklights? You might be able to achieve that look with 3 of those, though you'd have very little control over the beam. You'll need to rent a haze machine first of all - liberal use of haze will allow you to see the 'beam' as the light from the fixtures hits and reflects off the particles of the haze.
Ideally, you'd want a larger fresnel light to offer a more controlled beam to fire through the window.
#4 AlejandroGomez
AlejandroGomez
  • 56 posts
  • Germany
Posted 26 August 2014 - 03:30 PM
Thanks for the replies guys, You're right Mark, just 500w halogen worklights. I use one projector and some cardboard to achieve some handmade barn doors. This is a couple of frames extracted from a testing shoot with the canon 650D and the yashica 28mm 2.8.
1534787_608737702579995_3876800343495861
10457450_608737622580003_489999072992118
