Is SM7b a good alternative to Sennheiser 416 or Rode NTG 3?
#1 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 08 April 2014 - 04:02 AM
I am gathering resources for a feature I'll be shooting in the summer. Im trying to cut corners here and there to get it done and I talked to some vocalists who said that Shure SM7b is great for voice work, whether music, broadcast, or dialog work. I took them up on it and purchased on from Guitar Center.
What do you all think? Can the SM7b be a viable production mic (I plan to keep dialog to indoor controlled situations, mostly.) for a film?
Any feedback is appreciated. Oh, And I purchased a tube preamp with it to add some warmth to the voice.
#2 Dino Giammattei
Dino Giammattei
  • 63 posts
  • A mile west of the crossroads and the old circus grounds
Posted 19 September 2014 - 03:50 PM
The biggest issue your'e going to run into is the lack of gain with a dynamic microphone like the SM7. It was designed to be an in your face microphone used by radio announcers. Even if your preamplifier has 70db of gain you may still find it lacking for distant mic'ing. Comparing the dynamic SM7 to a condenser like a 416 is like comparing a sports car to a pickup truck. Both were designed to do what they do extremely well. They're just not what you could consider interchangeable.
As far as a "toob" preamp, unless you spent more than a thousand dollars on it, you probably have what is referred to as a starved plate design. With this type of preamp the heavy lifting is done by a solid state operational amplifier and the "toob"is pretty much a distortion maker. The plate voltage in the "toob" is made intentionally low to cause the waveform to flatten out, theoretically adding pleasant harmonic distortion to the clean signal. This may actually work for VO if your'e careful with your levels, but generally you would be better served to have a quality preamp to begin with. Expensive... yes... But you're probably not shooting with Tamuron primes either.
Lastly.... Before you spend another penny on audio equipment, please contact me. I have thousands and thousands of dollars of recording equipment sitting around here and I don't want to admit to you how much of it was a waste of money.
Respectfully submitted, olduncledino
