ALEXA: peaking only MON OUT not REC OUT ?
#1 christian mann
christian mann
  • 53 posts
Posted 09 April 2014 - 06:31 AM
hey,
with the later software updates it seems to be impossible to have peaking ONLY on the MON out and NOT on MON out and  REC out at the same time.
Does anyone know how to bypass this?
It can be quite annoying when directors and clients have peaking on the monitors but still pretty helpful for focus pulling to have it on the onboard monitor....
thanx!
#2 Kar Wai Ng
Kar Wai Ng
  • 127 posts
  • Toronto, Canada
Posted 09 April 2014 - 09:01 AM
Peaking and status info should not appear on the REC OUT unless the REC OUT has been set to clone the MON OUT.
When in high speed mode, the REC OUT is automatically set to clone the MON OUT.
#3 christian mann
christian mann
  • 53 posts
Posted 09 April 2014 - 09:43 AM
I believe the software update is set in a way that REC out is set to clone MON out. A DIT also couldn't figure out how to "unclone" the REC out...
#4 Kar Wai Ng
Kar Wai Ng
  • 127 posts
  • Toronto, Canada
Posted 09 April 2014 - 08:01 PM
Were you shooting 2K instead of HD? This also forces REC OUT to be a MON OUT clone.
#5 Dom Jaeger
Dom Jaeger
  • 1811 posts
  • Melbourne, Australia
Posted 09 April 2014 - 08:32 PM
It's always helpful to be more specific about your camera settings.
According to the latest upgrade release notes, setting the ProRes recording resolution to 2K limits the options for REC OUT to ARRIRAW or MON OUT clone. When SxS recording is deactivated in this state, the REC OUT limitation remains. To get a clean HD image on the REC OUT, you need to switch back to HD recording before deactivating the SxS module.
#6 christian mann
christian mann
  • 53 posts
Posted 10 April 2014 - 01:46 AM
I see. Indeed we were at 2K when I came across this problem. Will check what it looks like with HD. Thanks.
