RCA line out to Blackmagic Cinema Camera?
#1 Vadim Joy
Vadim Joy
  • 209 posts
  • Los Angeles, London
Posted 19 April 2014 - 04:28 AM
Hi, I'm running microphone to the Shure FP33 mixer, then output the signal to Marantz PMD661 to record the audio. I purchased an RCA to 1/4 jack cable to run signal straight to the camera from Marantz and realized that RCA cannot be balanced, and Blackmagic requires balanced signal. Damnit. Is there another way to send signal from Marantz to Blackmagic?
#2 Freya Black
Freya Black
  • 4166 posts
Posted 19 April 2014 - 08:15 AM
Okay you can run an unbalanced signal into a balanced input but obviously it won't be balanced.
You need to have the wiring correct however.
The easiest way if you are not going to wire up your own cables might be a cable to convert the 1/4 jacks into XLR sockets and then another cable to take the phono output and turn it into an XLR plug.
Here is an example:
http://www.markertek...PS-XLF-03.xhtml
Note how the jacks on this cable are STEREO! This is because the stereo jack carries both the in phase and out of phase audio signal for a connection.
Heres a nice little box that does the same thing:
http://www.thecineci...H-ABOX-BMC.html
Once you have a cable like this then if you have a phono to XLR cable it will also be wired correctly as phono is unbalnaced and XLR is balanced.
Freya
#3 Freya Black
Freya Black
  • 4166 posts
Posted 19 April 2014 - 09:04 AM
Then I had a bath and realised you could also get away with a stereo jack to 2 phono cable and just ignore one of the phono sockets. :)
...or at least I think you could.
Going XLR might make things easier for other stuff tho.
Freya
Edited by Freya Black, 19 April 2014 - 09:05 AM.
#4 Vadim Joy
Vadim Joy
  • 209 posts
Posted 19 April 2014 - 09:06 AM
Wouldn't it be easier if an electrician can simply change 1/4 to xlr to make it balanced? And then run xlr to 1/4 into the camera?
#5 Vadim Joy
Vadim Joy
  • 209 posts
Posted 19 April 2014 - 09:13 AM
Like this: Marantz > RCA - male xlr > female xlr - 1/4 jack > camera
#6 Freya Black
Freya Black
  • 4166 posts
Posted 19 April 2014 - 10:51 AM
Yup that's what I suggest in my first reply above. :)
You wouldn't even need an electrician, you can use off the shelf cables like I linked to.
That would probably be most straightforward as once you convert the jacks to XLR it's all kinda standard.
Freya
#7 Freya Black
Freya Black
  • 4166 posts
Posted 19 April 2014 - 11:04 AM
Heres a cheap adapter to XLR:
http://www.ebay.com/...=item43c89a3014.
Might be hanging a lot of weight off your jack sockets tho compared to a cable.
Freya
Edited by Freya Black, 19 April 2014 - 11:04 AM.
#8 Freya Black
Freya Black
  • 4166 posts
Posted 19 April 2014 - 11:22 AM
Heres some more cables:
http://www.ebay.co.u...s-/290976283962
Right angled cables to protect your jack inputs:
If you search, maybe you can find a similar cable that will work for you at a better price.
You need XLR to 1/4" TRS jack.
Freya
#9 Vadim Joy
Vadim Joy
  • 209 posts
Posted 19 April 2014 - 07:56 PM
Thanks Freya, I appreciate it. I ordered few cables. Will do some tests when they arrive.
