Optimo or DP Rouge
lens angenieux dp prime zoom
#1 Timothy Vandenberg
Timothy Vandenberg
  • 1 posts
  • Wilmington NC
Posted 29 April 2014 - 02:33 PM
Hello,
There is a pretty considerable price difference between the Angeniuex optimo lens and the DP. Aside from the limitations of the Dp with film cameras, is there a substantial difference in image quality and lens speed between the two?
I shoot red one MX.. I understand the housing on the dp is a little "cheapy" but for how much more I will have to pay for an optimo, is the image  going to be that much more superior and in what ways?
Thanks for the input!
Tim
#2 Mark Kenfield
Mark Kenfield
  • 1202 posts
Posted 29 April 2014 - 07:52 PM
Angie have actually just announced revised versions of the DPs which don't have the deep throat of the originals - so they'll now work just fine with both film cameras, and digital cameras like the Alexa XT (with its internal NDs) and the Epic (with its motion mount).
#3 jay obertone
jay obertone
  • 17 posts
  • san francisco
Posted 29 April 2014 - 09:57 PM
I cant speak for a direct comparison, but I have done some work with the DP's and find them to be fantastic.
#4 Freya Black
Freya Black
  • 4166 posts
Posted 30 April 2014 - 10:01 AM
Someone I know who put both the DP's and the regular optimo zooms on a projector told me that they performed identically.
Whether that is still the case for the new versions I have no idea.
Freya
#5 Silvan Liu
Silvan Liu
  • 2 posts
Posted 30 April 2014 - 05:56 PM
From what I've seen on a projector the Optimos have less distortion, breathing and chromatic aberration than the DPs. However I was also comparing the Alura Lightweight zooms (priced similar to the DPs and with similar zoom ranges) and they performed even better than the Optimos. Definitely try to get a look at these lenses on a projector yourself if you get a chance.
#6 Dom Jaeger
Dom Jaeger
  • 1817 posts
  • Melbourne, Australia
Posted 01 May 2014 - 01:21 AM
We have both in our rental fleet, there is definitely a difference but I'd say it's mostly in build quality. The distortion (some barreling) and breathing (hardly any) are identical between the 16-42 DP and the 15-40, but chromatic aberration is slightly worse in the DP. I don't have our 30-80 DP here at the moment to throw up on my projector but from memory it's the same sort of difference to a similar range Optimo like the 28-76. When we asked an Angenieux rep about it he said they built the DPs to a lower resolution spec but I can't really see that on projection, except maybe very slightly in the corners at full aperture. The tolerance of focus drift through the zoom range might be a little less stringent. But past about T4 or 5.6 I don't think you could pick them to be honest.
The DP build feels different though, the zoom mechanics are lighter to the point where after some use and wear you might get a bit of creep if the zoom is tilted without a Preston fitted for example, and they make more noise. I would predict their lifespan to be shorter than an Optimo's. Some of these issues are of more concern to a rental house than to a production. If the budget isn't there, I don't think renting DPs instead of Optimos will be any sort of problem.
Most cinema release features tend to choose Optimos though, unless it's a 3D production where matched DPs often get used.
As is often the case with optics, it's that last 5 or 10% improvement that doubles the cost. Allowing the rear element to be much closer to the film plane reduced some of the optical design difficulties and hence the final cost of DPs also, but it's interesting that Angenieux have gone back to normal clearance for the new Optimo Style series.
Also tagged with one or more of these keywords: lens, angenieux, dp, prime, zoom
