Canon C300 LUT on set
#1 Joe Saadeh
Joe Saadeh
  • 6 posts
Posted 09 May 2014 - 03:17 AM
Hello Everyone,
I have a few questions to ask, Ill be shooting a web series next week and i would like to be using the most out of the C300 and shoot C-log my only problem is that you can't send a LUT out of the SDI from c300.
Any monitors you can recommend that has built-in C-log LUT ?
my other question is regarding frame-rate
I live in a Pal region ; although this is a web-series and not a broadcast thing i wanted to know if i shoot 23.97 fps would affect this. I'm asking this because I'll be using some HMI fixtures and shooting with fluorescent light.
Many thanks
Joe Saade
#2 aapo lettinen
aapo lettinen
  • 1136 posts
  • Finland
Posted 09 May 2014 - 04:13 AM
if you are using 1/50 or 1/100 shutter speed the flicker is not a problem at any frame rate
#3 Phil Rhodes
  • 12163 posts
Posted 09 May 2014 - 04:27 AM
I'd consider shooting at 25. It isn't noticeably different-looking, it obviates problems with lighting flicker and it can easily be retimed to 24, and thence to 30 if you need that at any point.
Monitors tend not to have built-in LUTs, but allow you to upload one. You can also get something like a Blackmagic HDlink (I own one) which you can use to convert your camera's SDI signal to DVI and run it into a normal computer monitor or similar for a reasonable approximation of the same thing.
