I'm confused!
13 replies to this topic
#1 Jay L Smolowitz
Jay L Smolowitz
  • 2 posts
Posted 02 June 2014 - 03:55 PM
I just ordered my first set of 16mm film ever. I went with daylight stock just so I can goof off an test out the camera. However, I was kind of thrown off by it saying on the pacakage: 3200 daylight.
This may sound dumb but I thought 3200 was tungsten and 5600 was daylight. Does that not apply or have the same meaning as the daylight stock and tungsten stock?
#2 Adrian Sierkowski
  • 7488 posts
Posted 02 June 2014 - 04:02 PM
It does apply, but just because the film is Daylight, doesn't mean you can't use a filter to balance it.
What is the stock number?
such as 7207
When you look at it, does it have a "D", such as 250D
You'll notice on the table it'll have 3200K and a different ISO value (160 if memory serves) , this is for the 85 filter factor's effect on the "speed" of the film, the same as opening up 2/3rds of a stop.
http://motion.kodak....es/H20_2pgs.pdf
#3 Jay L Smolowitz
Jay L Smolowitz
  • 2 posts
Posted 02 June 2014 - 04:06 PM
I actually just looked at it again. Its say 3200k with filter 80a next to it. I'm assuming if I shoot the daylight under tungsten lighting I need filter 80a to correct it. I over thought and misread. Being my first time shooting film ever, I'm super paranoid.
Thanks man!
#4 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 02 June 2014 - 04:27 PM
Thanks man!
Paranoia is good when shooting film...it keeps you from making costly mistakes. Have fun!
#5 Steve Zimmerman
Steve Zimmerman
  • 196 posts
  • Charleston, SC USA
Posted 03 June 2014 - 09:17 AM
It's often a good idea to overexpose 2/3 to one full stop to get tighter grain, brighter colors and contrast.  In the past I sometimes got blah images if i didn't.
Edited by Steve Zimmerman, 03 June 2014 - 09:19 AM.
#6 Mark Dunn
Mark Dunn
  • 2798 posts
Posted 03 June 2014 - 11:30 AM
If you did want to shoot daylight stock indoors, the 80A filter absorbs 2 stops, whereas to convert tungsten stock to daylight requires an 85 filter which only absorbs 2/3 stop. So if you wanted to shoot indoors as well, you'd be better off with tungsten stock.
#7 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 03 June 2014 - 12:12 PM
I use to spout this too but it is really not the way you should plan your shots around. The whole "tighter grain" thing is bogus when compared to slower stocks generally. For example, you will get tighter grain shooting 200t at proper exposure than 500t overexposed by a stop.
I think sometimes we just say things because it is the popular thing to say and we dont actually go check the results for ourselves. And brighter colors has more to do with your colorist than how you are shooting a (low contrast) negative.
#8 Gregg MacPherson
Gregg MacPherson
  • 1966 posts
  • New Zealand
Posted 03 June 2014 - 03:08 PM
I just ordered my first set of 16mm film ever. I went with daylight stock just so I can goof off an test out the camera. ...
Is that 250D?  If you end up inside with a reasonable amount of daylight and you want to add a little with one or two tungsten lights you can just use CTB gel on them.
#9 Giray Izcan
Giray Izcan
  • 404 posts
Posted 03 June 2014 - 06:11 PM
Overexposing for tighter grain applies in the world of photochemical finish. You end up pushing more printer light through a thick negative.
#10 Stuart Brereton
Stuart Brereton
  • 3396 posts
Posted 03 June 2014 - 07:50 PM
As it's the OPs first ever rolls of film, I'd suggest that he expose it at box speed, and get used to using it, rather than instantly embarking on non standard procedures  which he doesn't necessarily understand.
Underrating a stock is merely a way of getting the tightest grain out of it. Is it going to make a 500asa stock look like a 200asa? No, but that's not the intention anyway.
By over exposing your image you are placing more of your picture information on the upper part of the characteristic curve, which is where the finer grains are. So your negative appears finer grained whether finished digitally or photochemically.
#11 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 03 June 2014 - 09:03 PM
Then what exactly is the point of shooting 500t exactly? If you need low light? Fine but if you are going to rate it slower anyway then why shoot it? I hear fanboys for this stock all the time but never hear why it is supposedly so great.
#12 Stuart Brereton
Stuart Brereton
  • 3396 posts
Posted 03 June 2014 - 09:26 PM
I'm sure I don't have to explain the benefits of a 500 speed stock over a 200 speed stock for night and low light shooting. As for underrating it, common practice would be to rate it at 320ISO, which still gives a significant speed advantage over 200t, while retaining the ability to rate it faster if the need arises.
Some people like the texture of the coarser grain, some people like the highlight handling. It's not inherently better or worse than 200t. You could equally argue that you should shoot 100t rather than 200t or 50D not 250D. There are times when you need the speed, and times when you want fine grain. That's what the choice is for.
#13 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 03 June 2014 - 09:59 PM
I shoot 16mm and I have never seen 100t? Isnt that only 35?
#14 Stuart Brereton
Stuart Brereton
  • 3396 posts
Posted 04 June 2014 - 12:35 AM
5212/7212 was 100 Tungsten. Apparently it was discontinued back in 2010, which is probably about the last time I shot any film.
