Distance for Wide Shot
#1 David Schmüdde
David Schmüdde
  • 27 posts
  • New York City
Posted 04 June 2014 - 09:56 AM
I'm building stage setup and I need a specific number to estimate the amount of space I need.
What I need to know is the distance necessary between a 6' tall subject and the camera for a wide shot. For some reason, I'm blanking on how to figure this. These are the constants:
  • 35mm sensor size
  • 50mm lens length
  • 6' Tall Subject
  • Wide Shot (includes top of the head to bottom of the feet)
  • 16x9 frame dimension
What I need to solve for:
  • Distance between camera and still subject
Could someone help me here?
#2 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 04 June 2014 - 10:10 AM
It's a straight bit of similar triangle geometry.
Frame height for 16:9 is about 10mm. Focal length 50mm. 50/10=5 so distance is 5x height- about 10m.
Edited by Mark Dunn, 04 June 2014 - 10:14 AM.
#3 David Schmüdde
David Schmüdde
  • 27 posts
  • New York City
Posted 04 June 2014 - 01:40 PM
Thanks for your help. I was thinking about it by considering the size of the image on the sensor/film. Thinking about this in landscape mode:
35mm full frame is 36mm×24 mm - 1.5 aspect ratio
35mm HD TV is 36mmx20.25mm - 1.77 aspect ratio (16 : 9 = 36mm : X)
My formula
Hc (film height) / Lc (distance from lens to film) = Hh (human height) / Lh (distance from lens to human)
Hc = 20.25mm
Lc = 50mm (focal length of lens)
Hh = 1.8m (6' - a constant given above)
Hc / Lc = Hh / Lh
.020m / .050m = 1.8m / Lh
Lh = 4.5m or 15'.
Did I do something wrong here?
#4 Jaron Berman
Jaron Berman
  • 182 posts
  • New York, NY
Posted 04 June 2014 - 09:29 PM
What do you mean by 35mm frame?  35mm still?  s35?
For super 35 frame (most d-cinema cameras, 7d, etc), 16:9 HDTV, its about 24' on a 50mm
For 35mm still frame (like 5d), it's about 16'
Edited by Jaron Berman, 04 June 2014 - 09:32 PM.
#5 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 05 June 2014 - 11:58 PM
I'm not so great at math, but, isn't 10 meters more than 30 feet? For a head to toe on a 50mm? It seems a little much. If you want to wait till tomorrow, I'll stand up my tape measure and check it through my 50mm on my old Nikon and then pace it off.
#6 John E Clark
John E Clark
  • 850 posts
  • San Diego
Posted 06 June 2014 - 04:47 PM
For those who don't want to 'do the math', which is tedious and if there are changes, needs to be recalculated...
For the iPhone:
http://www.davideuba...Calculator.html
Or
https://itunes.apple...d377419210?mt=8
Using the Field of View calculators you can easily get what lens length for what FoV/AoV, etc. is required for what sized object, etc. for a variety of cameras.
#7 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 08 June 2014 - 05:40 AM
Yes, you didn't specify what '35mm. sensor size' meant, so I assumed Academy. Turns out you meant Vistavision.
I calculated the AR from frame height, not width, so I was a bit off too. t would actually be about 5m.
The other thing you did wrong was asking the question when you'd already worked it out yourself.
This forum isn't an exam.
#8 Diego Treves
Diego Treves
  • 23 posts
  • Milan
Posted 29 October 2015 - 09:36 AM
Edited by Diego Treves, 29 October 2015 - 09:42 AM.
#9 Peter Hodgins
Peter Hodgins
  • 8 posts
  • Toronto
Posted 23 January 2016 - 03:51 PM
  • 35mm sensor size
  • 50mm lens length
  • 6' Tall Subject
Can you just slap a 50mm lens on your dslr and frame a 6 foot subject or perhaps a doorway etc. in your 16x9 frame, and note your distance?
