Avoiding Hot Spots in interview lighting setups
hotspots hot spots interview softbox rifa lighting
13 replies to this topic
#1 MICHAEL TAPP
MICHAEL TAPP
  • 18 posts
  • 2nd Assistant Camera
Posted 10 June 2014 - 03:34 PM
Hi All,
I recently picked an ex88 rifa softbox to shoot talking heads. I recently tested it out and ran into an issue with hot spots on the subject's face. The silk on the rifa is 32x32 inches and I was also using the eggcrate. The source(1k) was about four feet from the subject. I didn't try using powder during the test. Is there anything else I can do with the softbox to avoid hot spots? Thank you for your insight and time!
#2 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 10 June 2014 - 03:51 PM
What do you mean by hotspots? If you mean specular reflections and shine from skin, then you'll get that from any lamp. You need to use powder to deal with it.
#3 MICHAEL TAPP
MICHAEL TAPP
  • 18 posts
Posted 10 June 2014 - 03:56 PM
Yes, I am referring to specular reflections and shine on the skin. Thanks for clearing things up for me.
#4 Chad Griepentrog
Chad Griepentrog
  • 16 posts
Posted 11 June 2014 - 01:38 AM
Does your kit come with a baffle? That should eliminate any hot spots and spread the light evenly by the time it hits your silk. Is the light fully flooded?
#5 MICHAEL TAPP
MICHAEL TAPP
  • 18 posts
Posted 11 June 2014 - 11:52 AM
Are baffles another word for egg crates? I have a 40 degree egg crate. I'm thinking of trading in the 40 degree egg crate for a 30 degree egg crate.
And yes, the Rifa softbox is fully flooded. Because of the construction of the softbox you can't move the bulb.
Edited by MICHAEL TAPP, 11 June 2014 - 11:54 AM.
#6 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 11 June 2014 - 03:51 PM
A baffle is typically a second layer of diffusion inside the softbox. I don't think Rifas have them.
#7 Mark Kenfield
Mark Kenfield
  • 1201 posts
Posted 11 June 2014 - 08:58 PM
Taping or clipping an additional sheet of diff over part of the softbox can help cut down those specular reflections without affecting the rest of the light too much.
#8 MICHAEL TAPP
MICHAEL TAPP
  • 18 posts
Posted 11 June 2014 - 11:10 PM
Thanks for the tip! What level of diff would you recommend? I'd like to kill the hot spots without losing too much light.
#9 Mark Kenfield
Mark Kenfield
  • 1201 posts
Posted 12 June 2014 - 11:12 PM
I'd bring sheets of 216, 250 and 251 along and see what it needs. Powder to create more of a matte sheen on people's skin can go a long way for these things though.
Edited by Mark Kenfield, 12 June 2014 - 11:12 PM.
#10 Adrian Sierkowski
  • 7485 posts
Posted 13 June 2014 - 06:47 PM
All the diff you add, don't forget, will have the effect of dimming down the light; which often means you bring it in closer, which then takes away a level of it's softness. There is no free lunch.
#11 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 13 June 2014 - 09:58 PM
Another thing you can do is add a 4x4 frame of diffusion in front of the soft box. Try Light Gridcloth. That will make your key light even softer, so the reflection in the skin will be broader and more diffuse.
As Adrian says, you will lose some stop by doing this.
#12 Mathew Rudenberg
Mathew Rudenberg
  • 252 posts
Posted 13 June 2014 - 10:05 PM
Bringing it in closer would actually increase the amount of softness - a small frame near by creates the same size light source (relative to the subject) as a large frame far away.
#13 Adrian Sierkowski
  • 7485 posts
Posted 13 June 2014 - 10:07 PM
Ahh you are correct Mathew. Sorry long flight this morning.
#14 Carl King
Carl King
  • 37 posts
Posted 14 June 2014 - 12:18 AM
It does sound like the simple solution would be more makeup. And making sure you're not overexposing / clipping the highlights.
