Video Transmitters
video transmitters nab cinege
#1 Peter Jensen
Peter Jensen
  • 16 posts
Posted 18 June 2014 - 01:10 PM
Anyone have have views purchasing video transmitters state of the art?   Also, what are the important things to consider in deciding on a purchase of transmitters these days, including the options for high end transmitters.
#2 Rob Vogt
Rob Vogt
  • 437 posts
Posted 18 June 2014 - 08:14 PM
Well one of the main things to consider is what you are going to use it for. There are many instances where you might want a single transmitter to go to a couple of receivers and many can not achieve this. Then there's the type of signal- ie HDMI (paralynx arrow, asus) or HDSDI (Teradek Bolt, Camwave, Boxx Meridian). If you want to encode your signal and stream it then there are many other options for live events and Teradek Cube.
Then there's price, weight, reliability, FCC regulations, range, ability for line of sight, available mounting options, latency, whats available in your city.
#3 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 19 June 2014 - 06:19 AM
Latency is likely to be a major problem. Just about all of them use  some sort of MPEG4 compression, which means there is a considerable processing delay, because the endoder needs to snare a complete GOP (Group Of PIctures) befpre it can make each transmission packet. The theoretical  minimum delay is usually around 1/2 second, but in practice it can be much longer.
This is no problem if you just want to stream pre-recorded material from a Blu Ray player or the like, but hopeless for live monitoring.
If it's just live monitoring you're after, old-fashioned composite video is probably still your best bet.
