35m SLR lens mod- Fiddling with pin to adjust f-stop
#1 Sir Alvin Ekarma
Sir Alvin Ekarma
  • 211 posts
Posted 20 June 2014 - 03:52 PM
I'm going to do some lens tests with my newly overhauled beaulieau and I noticed that the 50mm M42 SLR lens that I want to test doesn't have the setting to let you manually adjust the exposure, so the only way to use it is to fiddle with the pin on the back of the lens so it stays permanently depressed. Is there a trick to this? Can I just file it down some and then press it back into the lens? I've see some things online where they flat out take apart the lens to modify and that seems like a hassle.
#2 Dom Jaeger
Dom Jaeger
  • 1814 posts
  • Melbourne, Australia
Posted 20 June 2014 - 08:33 PM
If you can't find an adapter that works with auto only M42 lenses you'll have to do some modification, this site has some suggestions:
http://www.instructa...ic-Only-Lenses/
#3 Sir Alvin Ekarma
Sir Alvin Ekarma
  • 211 posts
Posted 20 June 2014 - 08:43 PM
Thanks. The third option sound pretty good.
