16mm gang synchronizer
#1 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 21 June 2014 - 10:38 AM
I used one of these for my last short and there is one thing I could never understand: why are the sprockets located on the top wheel of each section, rather than the bottom, since when using single-perf film, the film moves from left to right with the perforations on the bottom edge of the film (as when using a flatbed editor like a Steenbeck)?
Last time, I just turned the thing around, but the wheel with the frame numbers was not visible, so I had to keep turning it back around in order to see what frame I was at.  I'm guessing I was just doing something wrong.
I plan on buying another soon, hence the timing for the question.  Here's a picture.  Any help would be appreciated.
Thanks a lot.
Edited by Bill DiPietra, 21 June 2014 - 10:40 AM.
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 762 posts
  • Montreal, Canada
Posted 21 June 2014 - 12:23 PM
Because many of these units were equipped with sound heads so the oxide side of the mag film had to be on top and the sprockets away from the user.
JL
#3 Charlie Peich
Charlie Peich
  • 248 posts
  • USA
Posted 21 June 2014 - 02:53 PM
You could 'special order' a synchronizer with the teeth nearest the operator (Moviola as you've pictured). You could also have the counter set to 'add' for right to left operation.
You don't see many conformed that way. I think the only time I saw a synchronizer with teeth nearest the operator was in a lab.
Also, you could order with the sound head above or below. Ask Moviola.  ^_^
I found this picture of a Ediquip synchro (almost an exact copy of the Moviola equipment) with the teeth conformed towards the operator.
This is a rear shot of the synchronizer, the arm latches are on the left in the pic, normally on the right side in the operating position.
The sprocket with the mag pick-up is in the 'teeth away' from operator position. The next 2 sprockets have the 'teeth towards' operator.
If you are mechanically inclined, you could take the synchronizer you have apart and turn the sprockets around to the way you want them. Moviola's 16mm sprockets are held in place with a hex set screw.
The mag pick-up could be adjusted easily if you have the support assembly that looks like the one above.
Charlie
#4 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 21 June 2014 - 03:00 PM
Thanks a lot for the info!
