What should I rate Kodak Tri-X 7266 when processing as negative?
Trix negative reversal bucket processing experimental
#1 Jon Taala
Jon Taala
  • 11 posts
  • Chicago
Posted 12 August 2014 - 10:35 AM
Hi All,
I currently want to shoot some 16mm Tri-X for an experimental film I'm making. I'm going to do bucket processing, but I want to bucket process as a negative.  I keep reading in onine and in other forums here that if you shoot reversal film and want to process as a negative you need to overexpose a little bit when filming. Since I'm shooting this in daylight and the EI for daylight is 200, I was wondering what I should rate my film at. Should I overexpose by 1 stop or 2 stops etc. or would processing it for longer work also?
Thanks for the help!
Edited by Jon Taala, 12 August 2014 - 10:36 AM.
#2 Robert Houllahan
Robert Houllahan
  • 1630 posts
  • Providence R.I.
Posted 12 August 2014 - 11:04 AM
Don't overexpose it too much, even when you run it as Negative it retains the reversal character, I rate it about 2/3 of a stop slower as Neg but that can be compensated for in developing too if you want to rate it as normal.
#3 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 12 August 2014 - 01:53 PM
Yeah, I usually just rate it at 200. Tri-x as a negative is going to be contrastier and grainier than it would be as reversal, so sometimes I'll overexpose a stop and pull process a bump. But honestly the difference is pretty minimal. I can't recall if I've ever tried two stops. I feel like I must have at some point.
  • 1
#4 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 12 August 2014 - 01:59 PM
Just for reference, here's some tri-x I rated 200 and pushed processed about 1 stop to compensate.
  • 1
#5 Jon Taala
Jon Taala
  • 11 posts
  • Chicago
Posted 13 August 2014 - 11:48 AM
Thanks guys!
  • 1
Also tagged with one or more of these keywords: Trix, negative, reversal, bucket, processing, experimental
