Nizo 561 macro apeture issues
10 replies to this topic
#1 Chris Burke
Chris Burke
  • 1702 posts
  • Boston, MA
Posted 14 August 2014 - 06:43 PM
I just purchased a Nizo 561 macro for almost nothing and all is working except the aperture. I put two button cells in. The  ƒ stop indicator now works up to ƒ5.6m beyond that it does not move. Is this a typical problem? can it be fixed? would fresh batteries fix it?
#2 Anthony Schilling
Anthony Schilling
  • 1061 posts
  • Portland, OR
Posted 17 August 2014 - 03:02 PM
You need to use the Wein air cell px625 batteries for the light meter. If they are running low, the needle won't work at all or only go so far. My Nizo 481 did the same thing the other day (only went to 5.6 with manual control) so i put in 2 fresh air cells and now fully functional.
#3 Chris Burke
Chris Burke
  • 1702 posts
  • Boston, MA
Posted 19 August 2014 - 04:10 AM
I will try that. Do the batteries have to be the Wein brand?
#4 Mark Dunn
Mark Dunn
  • 2535 posts
Posted 19 August 2014 - 06:49 AM
Yes.
You can't cut corners on this- you have to use the expensive Wein cells. The voltage must be correct- 1.35V- and stable. Other PX625s are silver oxide and start off at 1.5V which gives an incorrect reading.
The Wein cell uses a zinc-air process to replace the mercury which was banned some time ago.
There is a voltage-correcting adapter but it is about £30 here and you'd need two.
#5 Chris Burke
Chris Burke
  • 1702 posts
  • Boston, MA
Posted 19 August 2014 - 05:04 PM
Thanks. I will look around for the Wein cells.
#6 Jean-Louis Seguin
Jean-Louis Seguin
  • 737 posts
  • Montreal, Canada
Posted 19 August 2014 - 06:33 PM
Sounds more like a mechanical obstruction that stops the aperture at f/5.6. If this is the case, replacing the batteries won't solve the problem.
Jean-Louis
#7 Perry Paolantonio
Perry Paolantonio
  • 486 posts
  • Boston, MA
Posted 19 August 2014 - 08:22 PM
I got some of these from Amazon, for my Nizo, last year. I think they were under $10.
-perry
#8 Anthony Schilling
Anthony Schilling
  • 1061 posts
  • Portland, OR
Posted 20 August 2014 - 12:22 PM
Jean-Louis
Without proper battery power, even manual controls barely work.
#9 Chris Burke
Chris Burke
  • 1702 posts
  • Boston, MA
Posted 22 August 2014 - 04:44 PM
They arrived today in the post. When I get home, I will let you all know if that fixes the issue, fingers crossed. Otherwise, I will probably send it to Duall Camera for a check up. I got it for nothing, so....
#10 Chris Burke
Chris Burke
  • 1702 posts
  • Boston, MA
Posted 22 August 2014 - 09:38 PM
The aperture is working. At least I can move it to any f stop. Which I couldn't do before. Any in Boston with a role they want to sell? I would love to shoot one this weekend.
#11 Anthony Schilling
Anthony Schilling
  • 1061 posts
  • Portland, OR
Posted 23 August 2014 - 12:43 AM
That's great! You can test the meter without a cartridge out in the daylight and see what kind of readings you get. Sans cart, your camera will meter at 100ASA on daylight settings, or i160ASA on tungsten setting. The filter switch on the Nizo works differently with ASA settings than most other cameras. For example, If you load a cart of 50 daylight, the cart will disable the filter but the ASA rating depends on the filter switch... Daylight setting will read the film as 40 (overexposing 1/3rd) and tungsten setting will read it as 64ASA (under 1/3rd). Basically, make sure the filter switch is always set on the right condition, whether it's automatically disabled or not. 200T will read 160T/100D, with the little extra exposure a good thing.TriX (160T/200D) you will just leave on Tungsten setting since the camera sensor maxes out at 160ASA, 500T will read as 160T or 100D, over by 1&1/3rd stops but then you just set it manually from there. happy shooting!
