Redhead bulbs exploding and potential eye damage
11 replies to this topic
#1 Alexander Thomas
Alexander Thomas
  • 4 posts
  • Australia
Posted 01 September 2014 - 02:39 AM
Hi there, I'm lighting with a combination of LED lighting and 800w redheads, and the latter have proved unfortunately volatile. I've had a few issues with exploding bulbs, and just wanted to know if they could pose dangerous in terms of eye damage for anyone in front of the light? The redheads themselves prevent glass from escaping but the explosions are quite bright. Obviously I don't want them to explode, I'm taking all the precautions to handle the lights carefully and only ever move the bulbs with gloves, but incidents can happen.
#2 Brian Drysdale
  • 5287 posts
Posted 01 September 2014 - 03:10 AM
You should always have a safety glass on the front of Redheads, that will retain any exploding material from the bulb. With that fitted the main effect is surprise or shock from the bang. I'd go for the glass over the safety wire meshes because any small particles will be retained inside the light housing.
The only time I've seen a problem is when a safety glass wasn't fitted, although no damage was done, a hot bulb isn't the best for the carpet or landing in someone's lap.
#3 Gregg MacPherson
Gregg MacPherson
  • 1966 posts
  • New Zealand
Posted 01 September 2014 - 09:07 PM
....800w redheads...... I've had a few issues with exploding bulbs... The redheads themselves prevent glass from escaping but the explosions are quite bright.
Are you using the best quality bulbs? Are you ever using the lights in a way that limits heat disipation. In an enclosure, or pointed straight at the ground for example.
#4 Alexander Thomas
Alexander Thomas
  • 4 posts
  • Australia
Posted 02 September 2014 - 03:20 AM
The bulbs are good quality, and never using the lights in a way that limits heat disipation. All I'm really wondering about is if the flash of a potential explosion could be dangerous to the eyesight of anyone in front of it?
#5 Brian Drysdale
  • 5287 posts
Posted 02 September 2014 - 03:24 AM
The flash isn't that bright, reflected sunlight from windows etc is much brighter, as is a flashbulb. It doesn't last that long either,
#6 Phil Rhodes
  • 12303 posts
Posted 02 September 2014 - 03:40 AM
Of course the other reason for having glass in front of something like that is that quartz halogen bulbs (which a redhead uses) have high enough energy to emit quite a bit of UV even under normal operating conditions. Many kinds of plain glass behave as at least something of a UV stop filter.
#7 Alexander Thomas
Alexander Thomas
  • 4 posts
  • Australia
Posted 02 September 2014 - 09:32 PM
Thank you!
#8 Alexander Thomas
Alexander Thomas
  • 4 posts
  • Australia
Posted 02 September 2014 - 09:35 PM
Incidentally where would I buy safety glass from?
#9 Brian Drysdale
  • 5287 posts
Posted 03 September 2014 - 01:37 AM
Safety glass is supplied by the manufacturer, so you'd buy it from whoever you bought the light from or from the manufacturer's main agent in Australia. It's usually listed in the catalogue.
Redhead has become a generic term, originally it was a design of film light by Ianiro and the term was used for that unit, but now a number of manufacturers sell using that name. I assume it was never trademarked, the light was originally given that name by British film crews, while Ianiro refers to it as the Varibeam or the Ianebeam, not Redhead..
#10 Michael LaVoie
Michael LaVoie
  • 765 posts
Posted 04 September 2014 - 09:46 AM
I'd be worried that sealing up a redhead or a blond with glass would generate enormous heat that would actually blow the bulb.  Maybe I'm wrong. Fresnels obviously have enough venting through the top but those smaller hotlights sometimes dont cause the front is open face.  But always make sure that wire mesh or a scrim is used.
Red heads generally aren't used for talent.  You light background and the set with those open face lights and use fresnels or flourescents on subjects.  Both of those are more pleasing visually and offer more control than open face units.
Edited by Michael LaVoie, 04 September 2014 - 09:47 AM.
#11 Brian Drysdale
  • 5287 posts
Posted 04 September 2014 - 09:59 AM
The safety glass is a standard accessory on redheads provided by the manufacturers, I've got it in my Redheads and Blondes and the bulb life is usually close to what the manufacturers claim..
Redheads get used for all types of lighting situations, especially in documentaries, often with diffusion, a chimera or for bouncing light into reflectors. Their wide beam comes in useful in those situations.
#12 Gregg MacPherson
Gregg MacPherson
  • 1966 posts
  • New Zealand
Posted 04 September 2014 - 05:32 PM
... I've had a few issues with exploding bulbs....
What brand redhead are you using? What brand bulbs?
