Shooting Daylight Without a CTB gel on RedHeads
#1 Young Pizzy
Young Pizzy
  • 37 posts
  • Lagos, Nigeria
Posted 15 September 2014 - 08:25 PM
Greetings All
Pls I'm working on a Shortfilm and I'm thinking of how I'm going to light a room scene during the day to match up with daylight coming from windows with Redhead Tungstens without a CTB gel.
On my own I was thinking of:
1. Bouncing the Tungsten to a white surface.
2. Position my lights and tweak the color temperature on the camera.
Pls ur suggestions and thoughts will be appreciated.
#2 Albion Hockney
Albion Hockney
  • 479 posts
  • LA
Posted 15 September 2014 - 09:56 PM
it will never match daylight....the lights will look organge so you can play it like its coming from lamps or it can be a stylistic choice but know that it will never look "normal" you will have to create a stylized look and bouncing a light off of white will not effect the color temperature.
also generally a redhead is not near bright enough to match daylight so your backround will likley be overexposed still.
#3 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 16 September 2014 - 12:04 AM
If you can't correct them, you're better to key with the tungsten lights and balance your camera to 3200k. Just let the windows blow out to blue, it'll look more natural than having your interior overly orange.
#4 David Mullen ASC
  • 20068 posts
Posted 16 September 2014 - 01:14 AM
It won't match daylight without correction gel unless you bounce it off of a blue card. Or you can gel the window to match tungsten, but that's even more gel.
Adjusting the camera settings doesn't do anything about a mismatch between two colors in the same frame.
Bouncing a light off of a white surface does not change its color.
#5 aapo lettinen
aapo lettinen
  • 1135 posts
  • Finland
Posted 16 September 2014 - 02:18 AM
correcting the tungstens with 1/2 ctb can be enough in some cases, gives you one extra stop of light compared to full correction and 1/2 is usually enough to prevent the outside light from going overly blue
#6 Young Pizzy
Young Pizzy
  • 37 posts
  • Lagos, Nigeria
Posted 16 September 2014 - 01:04 PM
Thanks guys, good suggestions and I think I'll make do with Mark's idea.
Thanks David! I always learn from you.
#7 Young Pizzy
Young Pizzy
  • 37 posts
  • Lagos, Nigeria
Posted 16 September 2014 - 01:05 PM
And I thought again to use the Redhead as my backlight, cos I have a small white LED dat I'm thinking of using as my Keylight
