Nikkor ED 180mm f/2.8 Lens For PL help
#1 Tin Ojeda
Tin Ojeda
  • 42 posts
Posted 21 September 2014 - 11:17 AM
Hi .. im thinking of getting this lens for my Super 16 camera to shoot some surfing .. will this lens be 180mm in a super 16? or will it double the size since its a 35mm lens ?
Is this a sharp lens ?
#2 Adrian Sierkowski
  • 7488 posts
Posted 21 September 2014 - 12:48 PM
It will still be a 180mm lens, the only difference is a 180mm lens on S16mm has a smaller FoV (3.8 degree according to my calculator http://www.abelcine.com/fov/) which means in essence that if you were trying to match it on 35mm, then you'd need a 374mm lens.  I can't speak to the lens sharpness though it should be fine for your needs considering your real limiting factor on sharpness is the S16mm film.
#3 Tin Ojeda
Tin Ojeda
  • 42 posts
Posted 21 September 2014 - 03:35 PM
THANK U SO MUCH Adrian !
