SR3 high speed mag - is it usable on an SR2 ?
#1 P Mitcheltree
P Mitcheltree
  • 28 posts
  • Nova Scotia
Posted 05 October 2014 - 07:27 PM
Is the SR3 HS highspeed mag with timecode also compatible to run on the SR2 camera ?
Or does the focal flange on the SR2 need adjusting.  Thanks in advance.
#2 P Mitcheltree
P Mitcheltree
  • 28 posts
  • Nova Scotia
Posted 05 October 2014 - 08:24 PM
I am looking to use it on a regular SR2  not a high speed SR2.
#3 Dom Jaeger
Dom Jaeger
  • 1630 posts
  • Melbourne, Australia
Posted 05 October 2014 - 09:42 PM
Hi Paul,
Arri didn't recommended using high speed mags with standard cameras, or vice versa, but there shouldn't be any mechanical damage if you do. As you surmised, it's the difference in flange depth that's the problem. HS cameras are set 0.03 mm shorter than standard ones, due to the HS mag pressure plate design. This is not much, but might cause some softness on wider lenses at faster apertures, or cause a zoom to drift very slightly out of focus at the wide end.
#4 John Salim
John Salim
  • 183 posts
  • Essex, UK
Posted 06 October 2014 - 03:39 AM
I believe all high speed SR mags have fixed pressure plates whereas all standard mags have sprung plates.
John S :unsure:
#5 P Mitcheltree
P Mitcheltree
  • 28 posts
  • Nova Scotia
Posted 06 October 2014 - 05:58 AM
Thank you both, appreciate this.
