Russian Jupiter-9 lens with weird mount
#1 aapo lettinen
aapo lettinen
  • 1190 posts
  • Finland
Posted 24 October 2014 - 11:48 AM
I picked a Jupiter-9 , 85mm F2 lens off of eBay…
it has a mount which is definitely not oct-18 but not Arri standard either (mount diameter 46mm, full length of the mount 17.40mm, distance from the base to the front end of the locking ring about 11.65mm)
What it could be, is it some kind of older mount which was developed before oct-18 or just a experimental sample of some kind? It is definitely not a wrongly made oct-18 because the mount is much shorter and the locking ring is at different place, although the mount works mechanically the same way than oct-18
images: the lower lens is real oct-18 lens and the upper is the lens with the weird mount
#2 Phillip Mosness
Phillip Mosness
  • 98 posts
Posted 26 October 2014 - 09:23 PM
I recently received a 50mm lens with the same mount thinking I was getting an OCT-18. The seller allowed me to return the lens. It was odd because it was so close that I was fooled by the pics. I never found out what the odd mount and luckily it didn't cost me anything, but now I'm a little more careful.
#3 aapo lettinen
aapo lettinen
  • 1190 posts
  • Finland
Posted 22 November 2014 - 04:04 PM
OK, I accidentally found out what this mount is and which camera it is used in.
It seems to be the mount of the Russian AKS-4M camera which is somewhat direct copy from Arri 2 camera with minor changes (copied from A or B model Arri?? )
If you look closely this shot of a Soviet propaganda film you can see those cameras on the upper shelf filming a nuclear test:
http://www.youtube.c...NSTW8xfKU0#t=47
#4 Stefan Fischer
Stefan Fischer
  • 48 posts
  • Deutschland
Posted 21 May 2018 - 09:27 AM
Do you still have the lens and want to sell it?
#5 aapo lettinen
aapo lettinen
  • 1190 posts
  • Finland
Posted 21 May 2018 - 05:34 PM
I still have the AKS lens. using it for some macro tests, maybe modifying the mount later at some point.
do you have one of those rare AKS4 cameras you would use it with? :)
there seems to be at least one on eBay which is similar to my lens though with black housing
