how to rewire a colortran 6 fey mini brute from 220 to 110 with edison plugs
colortran mole fey mini brute maxi brute rewire 650 edison 220 to 110
#1 kelvincine
kelvincine
  • 1 posts
  • nyc
Posted 05 November 2014 - 10:49 PM
Hi All,
I'm an advanced digital filmmaking  student @ the Digital Film Academy, DFA, in NYC. My thesis film, calls for an elaborate, EXT NIGHT sequence, where sodium vapors are the over whelming light source. I found 2 Colortran 650 mini brutes, in hopes of over powering the sodium's with tungsten or day light source. My issue is the instruments came wired with two, two pinned pigtailed post. I assume, they are 220V.  I would like to rewire them to 110V Edison plugs. I can't decipher how to properly series them to either, 3 two light or 2,  three light configurations. Please advise.
#2 Phil Rhodes
  • 12299 posts
Posted 06 November 2014 - 05:07 AM
I don't want to pour cold water on the idea, but think people might be quite cautious about giving advice on this sort of thing. Mistakes can, obviously, be dangerous, up to and including starting fires and killing people. If you can't easily figure it out with a multimeter, you should probably give the job to someone who can.
Again, hate to be a downer, but that's honestly the best advice I can give you.
#3 JB Earl
JB Earl
  • 162 posts
  • NE PA USA
Posted 07 November 2014 - 11:40 AM
go to an electrical supply and ask them to recommend an electrician to do a small project.  I imagine it's a 1 or 2 hour job for someone like that.
#4 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 07 November 2014 - 01:49 PM
How are you planning to power these lamps? Remember, when you halve the voltage, you double the amps. Assuming they have 6 x 650w globes, that's 35 amps @ 110v, way too much for house power. You'll need something like a Honda 6500 for each lamp, unless you can find something smaller and silenced, as well as some 60amp Bates .
It would be much simpler to rent a couple of 1.2kw HMI Pars, or Arri M18s, if you have the budget, and run them from house power.
#5 Guy Holt
Guy Holt
  • 578 posts
  • Boston
Posted 08 November 2014 - 06:36 PM
If you can post a picture of the connection it would be helpful.
Guy Holt, Gaffer, ScreenLight & Grip, Lighting and Grip Rental in Boston
Also tagged with one or more of these keywords: colortran, mole, fey, mini brute, maxi brute, rewire, 650, edison, 220 to 110
