Good 16mm Projector
15 replies to this topic
#1 David Cunningham
David Cunningham
  • 1049 posts
Posted 07 November 2014 - 03:20 PM
Hello,
I am looking for suggestions about my 16mm projector and what/if I should buy another one.
It is a Kodak Pageant 250 series projector.
I ask because it has a small amount of noticeable flicker to it.  I'm wondering if this is because it's cheap in the first place and has a single opening shutter and if there is a better option out there... and... if it should not have this flicker what the likely problem is that's causing it.
Thanks for any advise you can offer!
Dave
#2 Simon Wyss
Simon Wyss
  • 1424 posts
  • Basel, Switzerland
Posted 08 November 2014 - 02:33 AM
My favourites are
  • Siemens & Halske 2000 for not too badly shrunken film
  • Paillard-Bolex S series
  • Bell & Howell Filmo and Filmosound series, apt for shrunken film
  • Diksi-Tfp.
  • Dixi 700 series
Edited by Simon Wyss, 08 November 2014 - 02:37 AM.
#3 Jean-Louis Seguin
Jean-Louis Seguin
  • 721 posts
  • Montreal, Canada
Posted 08 November 2014 - 08:00 AM
If you have the model with the two position shutter and you have flicker, maybe it is locked in the wrong position?
Check out the manual at:   http://www.film-tech...s/KODAK250S.pdf
Jean-Louis
#4 David Cunningham
David Cunningham
  • 1049 posts
Posted 08 November 2014 - 01:31 PM
Thanks Jean-Louis... investigating.
Is there such a thing as a triple flash/shutter 16mm projector?  i know there is in 35mm.
Dave
#5 David Cunningham
David Cunningham
  • 1049 posts
Posted 08 November 2014 - 01:42 PM
Dave
Nevermind... answered my own question when I started reading the link you sent... apparently my pageant is a 3 blade or 2 blade setup.
#6 Simon Wyss
Simon Wyss
  • 1424 posts
Posted 08 November 2014 - 02:03 PM
Most 16mm projectors have three-blade shutters, the Paillard-Bolex G3 was available with a switchable three and four blade shutter. It allows to screen at down to 12 frames per second without flicker. Paillard-Bolex S projectors are switchable two and three blades.
Siemens & Halske 2000 projectors also can be set to two or three interceptions.
Bell & Howell employed a single-blade shutter revolving at triple speed, the claw engaging only every third stroke.
Stationary sound machines often have a fixed two-blade shutter, I am recalling Cinelabor, Bauer Selecton, Philips EL 5000, the Eastman 25-30-40. Among the American brands you have more, such as Ampro, Keystone, National, Victor, RCA, TSI, Revere. The Kodascope Pageant, I do admit, is not so high in the ranking with me because of its plywood frame and some other oddities but you can tag that as snobism. On the other hand am I a professional projectionist. Conclusion: there are snobbish projectionists.
#7 David Cunningham
David Cunningham
  • 1049 posts
Posted 08 November 2014 - 11:28 PM
Jean-Louis
That did it! No more flicker! Thanks again Jean-Louis!
#8 Will Montgomery
Will Montgomery
  • 2033 posts
  • Dallas, TX
Posted 10 November 2014 - 10:47 AM
I bought one of these Telex projectors "new" from this eBay vendor about 6 years ago. They are old new stock I believe government surplus. I've had great success with it, threading is easy and less potentially dangerous to prints than some other projectors. He also has multiple lenses available for it including cinemascope I believe.
It's not as modern as some other projectors but seems like it was built like a tank to last.
http://r.ebay.com/wRKrxt
++!B-HYg!2k~$(KGrHgoOKjUEjlLmUhVfBKiG8,J
#9 David Cunningham
David Cunningham
  • 1049 posts
Posted 10 November 2014 - 12:19 PM
That's awesome! Thanks for that link. I wonder how easy that would be to covert to Super16 projection.
#10 Anthony Schilling
Anthony Schilling
  • 1058 posts
  • Portland, OR
Posted 10 November 2014 - 12:44 PM
I've had a couple of big and Heavy Bell&Howell's but i think my favorite for silent film is the old Revere 16mm. They are light weight and very portable, easy to thread manually with no auto-load, and I like the variable speed knob.
#11 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 10 November 2014 - 01:36 PM
is a keystone k-161 a good reliable projector?
#12 Will Montgomery
Will Montgomery
  • 2033 posts
  • Dallas, TX
Posted 10 November 2014 - 02:40 PM
Super 16 isn't a projection format...it's just for transfer. I've never heard of anyone projecting it. I guess you could widen the gate just like with a camera but you run into the problem of the bulb not being centered behind that widened gate...not sure if that would be an issue or not.
Now that I think about it, it would be fun to make Super 16 prints (is that even possible?) and view them in widescreen.
Let us know how that goes.
The guy who sells those projectors may have some insight for you; he's bought and sold projection equipment for many years.
#13 David Cunningham
David Cunningham
  • 1049 posts
Posted 10 November 2014 - 02:55 PM
I have a Kodak Pageant Super16 modified projector... Gate widened and lens re-centered.  Works great.
Cinelab in MA does Super16 contact prints from Super16 negatives.
#14 John Clere
John Clere
  • 6 posts
Posted 01 December 2014 - 07:30 AM
I'm no expert in the field of projectors, but my Ampro Stylist has served me very well. I bought it mostly for its looks, it's a remarkably beautiful machine, and it works well. It is pretty loud, if that's a problem, and it's not the easiest to thread. I always project through a glass door or window and run the sound cables under the door, that seems to get rid of enough of the noise for viewing.
Note that since it's so old, the sound is unbalanced. The sound has a lot of noise in it unless you use a great instrument cable, something like Mogami. And on the note of sound, it does have a microphone input, so if you're watching silent film or if you want to narrate something on the speaker, you can do it.
On the note of shutter, it does have a two blade shutter, which is fine for sound film but not so fine for silent film.
Honestly, it works well but even if it didn't I would use it just for its looks. Hope that helps.
#15 Simon Wyss
Simon Wyss
  • 1424 posts
Posted 01 December 2014 - 12:16 PM
The K-161 is a simple home projector. There are worse but there are also many better.
Do invest some $100 more and get something really fine. Again: Bell & Howell Filmo and Filmosound, Ampro K and Stylist
#16 Tyler Purcell
Tyler Purcell
  • 3889 posts
Posted 02 December 2014 - 05:25 PM
Personally, I love the Pageant. I've had the B&H's, I've had the Revere and Keystone's, the Elmo/Eiki. Heck I even have a Kodak Model A sitting in my basement, which still works great! For me, the Pageant is the only one I use. I love the projectors ability unload mid shot without damaging the film and sound-block bypass. Showing dailies is so easy because the film is so exposed, it makes for easy marking for edit points. I use to wrap the output of the film into a gang station next to a splicer and make edits right there on the spot for clients.
Anyway, that's my personal preference. It's also the first 16mm projector I owned. So it does have some sentimental value for me. The Ampro's are very nice however. ;)
Edited by Tyler Purcell, 02 December 2014 - 05:28 PM.
