C-Mount lens threading issue
#1 Cory Zapatka
Cory Zapatka
  • 37 posts
Posted 08 November 2014 - 11:30 PM
Hey All-- So I've acquired a Black Magic Pocket Cam, which has allowed me to dust off all of my old C-Mount lenses and put them to good use. My Kern 75mm f/2.8, however, seems to be acting strange. The C mount can now become unscrewed, which I don't remember it being able to do before-- see photo attached.
I don't think that this part of the lens should be able to detach completely from the camera mount. It basically comes right off of the focusing threads. Any insights about this would be greatly appreciated-- I know I haven't explained the situation in the best way, but hopefully the photo will help.
B3KNvgu.jpg?1
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 762 posts
  • Montreal, Canada
Posted 09 November 2014 - 10:30 AM
Either the distance scale ring was so far out of adjustment that at minimum distance the two parts of the focusing barrel came apart
or
The guide pin is broken.
Jean-Louis
#3 Cory Zapatka
Cory Zapatka
  • 37 posts
Posted 09 November 2014 - 12:41 PM
Thanks for the reply, Jean-Louis. Do you think this is a self-serviceable issue or something that is even worth looking in to getting fixed?
I could buy a new one for $150 or so, but I have a personal connection to this glass as it was my dad's old lens from his travels.
#4 Jean-Louis Seguin
Jean-Louis Seguin
  • 762 posts
  • Montreal, Canada
Posted 09 November 2014 - 01:56 PM
With a jeweller's screwdriver, loosen the screws around the distance scale ring and pull the rear part off the lens. Now put the mount back on the lens. The guide pin inside the mount should align with one of the grooves in the lens barrel. The mount should be able to slide smoothly in and out but not rotate. If that looks OK, take the mount off the lens and screw the rear part of the distance scale ring to the mount all the way, then back it off a little bit. Now take lens and rotate the distance ring to the infinitu mark. Reassemble the two parts and tighten the setscrews (snug, not too tight). The lens should now be able to focus from infinity to the minimum distance without coming apart. The distances marked will probably be incorrect and the lens might focus past infinity but at least it should be back in one piece.
#5 Cory Zapatka
Cory Zapatka
  • 37 posts
Posted 09 November 2014 - 08:26 PM
Ah, well there is the problem. As you first suggested, it seems like the guide pin has snapped off. Most likely from over tightening or trying to force the c-mount off (I think this may have happened when I left the lens on during the summer and the expansion made it extremely hard to take off). Either way, I think I'm going to have to either solder/weld a new guide pin that will fix the dimensions of the grooves on the lens barrel, or drill through the mount and install a pin that way. I think this would hold better.
Thanks for your help, Jean-Louis!
In the image you can see the small, grey area where the pin once existed.
Edited by Cory Zapatka, 09 November 2014 - 08:27 PM.
#6 Jean-Louis Seguin
Jean-Louis Seguin
  • 762 posts
  • Montreal, Canada
Posted 09 November 2014 - 09:21 PM
You can still use the lens even without the pin; the lens will rotate as you focus though.
Jean-Louis
