Looking for PL mount 35-50mm lens recomendation
#1 Bryan Fowler
Bryan Fowler
  • 33 posts
  • TN, GA, NC, Airports
Posted 23 November 2014 - 08:16 AM
Hi guys,
I'm looking for some super cheap glass. Something in the 35 to 50mm range.
I see some stuff on eBay from the Ukraine for pretty cheap, but it's 80 or 135mm.
Anyone have thoughts on some cheap glass sources?
I realize it's going to be rough glass, but that's ok for what I need it for.
Thanks!
#2 aapo lettinen
aapo lettinen
  • 1216 posts
  • Finland
Posted 23 November 2014 - 12:58 PM
one of the cheapest ways is to buy a T-mount to PL adapter and one of those ugly low-end T-mount primes from the 60's. I have seen at least 35mm and 50mm and sometimes 28 on eBay and tele lenses have more options to choose from
#3 aapo lettinen
aapo lettinen
  • 1216 posts
  • Finland
Posted 23 November 2014 - 01:00 PM
some m42 lenses with small body diameter can also be adapted to PL with screw-on adapters. For example 50mm Industars are small enough to fit inside the adapter
#4 aapo lettinen
aapo lettinen
  • 1216 posts
  • Finland
Posted 23 November 2014 - 01:10 PM
There is quite a lot of PL-adapted medium format Pentacon 6 lenses available mostly from Ukrainian ebay sellers. You can buy an bayonet-lock PL adapter (P6-->PL) and use it as an intermediate mount for the P6 lens set. These lenses are not very fast if you are using something in the 35-50mm range and may also have low contrast
#5 Bryan Fowler
Bryan Fowler
  • 33 posts
Posted 24 November 2014 - 08:52 AM
Thanks everyone for the advice. I'll check out these things and see what I can find.
#6 aapo lettinen
aapo lettinen
  • 1216 posts
  • Finland
Posted 24 November 2014 - 01:57 PM
if you consider Pentacon Six route I recommend this adapter, the manufacturing quality is very high and it's not overly expensive:
http://www.ebay.com/...=STRK:MEBIDX:IT
#7 Phillip Mosness
Phillip Mosness
  • 100 posts
Posted 26 November 2014 - 01:42 AM
What about Lomos in OCT-18 with a PL mount adapter?
Or these Helios 58mm f2
http://www.ebay.com/...=item1c498289d3
