help making your own dvd's
#1 steve waschka
steve waschka
  • 205 posts
  • Orlando, FL
Posted 30 November 2014 - 01:05 PM
This may be beneath the collective intellect of this group. But I would like to know if I should just give up on the idea. I would like to produce dvd's at the house from time to time in small numbers. I have an older dvd recorder but its compression artifacts have become intolerable to me. I have a medical machine but it has choked and stopped doing dvd.. only does vid files now. So I tried a few programs for the macbook pro. None worked smoothly. Anyone have something that works well they could recommend? I am running out of energy for the trial and error approach.
#2 Tyler Purcell
Tyler Purcell
  • 4388 posts
Posted 30 November 2014 - 01:57 PM
Umm… Toast works great! You can set the bit rate and it makes menu's + burns right out of the program.
I usually encode with Apple Compressor which is part of the Final Cut Pro Suite. It has a wide range of MPEG settings which allow for decent output, far better then any other tool I've used. The hardware encoders like a stand-alone DVD recorder, are garbage. You need a multi-pass system for variable bitrate in order to fit long-form content onto a DVD and make it look good. If you have a mac and can get compressor, I'd be more then happy to toss some settings your way. :)
#3 aapo lettinen
aapo lettinen
  • 1190 posts
  • Finland
Posted 01 December 2014 - 05:51 AM
I personally use Encore CS6 for dvd authoring. not a perfect tool and has some bugs sometimes but quite easy to use especially for simple dvd's
