List of main filters and their functions
#1 Alexander Boyd
Alexander Boyd
  • 152 posts
  • Europe
Posted 09 December 2014 - 05:03 PM
Hello everyone,
just wondering if there's a list/website that combines all or most filters and their respective effects? Sort of to help a newbie making the right choices in terms of filter selection.
Thanks in advance,
Alex
  • 20470 posts
Posted 09 December 2014 - 05:43 PM
http://www.cinematog...showtopic=62160
#3 Albion Hockney
Albion Hockney
  • 493 posts
  • LA
Posted 09 December 2014 - 05:47 PM
in terms of filters there are a few things everyone uses all the time then there are FX/Diffusion filters for stylistic choices.
ND filters cut down light with no change to the image quality so you can achieve a particular fstop at a given ISO. If you are using a digital camera and ALOT of ND (1.2 and above generally) you may also need a "hot mirror" filter which helps cut down IR pollution which can cause the picture to go a bit purple/red
Polarisers are for removing reflected light. for example if you are shooting a window they also help saturate the sky (google for more info...there is lots)
and then there are FX filters mostly which are made to lower contrast or create a soft/hazy look. there are a ton of options for this. but the Black Pro Mist filters are the most popular.
other then that there is a couple weird quirky things out there like star filters or streak filters but they are pretty much speciality use only.
#4 Alexander Boyd
Alexander Boyd
  • 152 posts
  • Europe
Posted 09 December 2014 - 06:01 PM
Thanks David and Albion, much appreciated.
