Lighting walking scene in a city
lighting walking low budget city Lighting youtube streets short film ambient light
9 replies to this topic
#1 Gabe Phillips
Gabe Phillips
  • 11 posts
Posted 21 December 2014 - 04:55 AM
Hi, I'm making a short film next year, and one of the scenes features two people walking the streets of a city, much like this ( see video below ) i was wondering if anyone could tell me what is the best way to light the actors to get that city night feel? or do i need any other lights at all, will the ambient light of the city do? keeping in mind my rig will consist of a glide cam, and a Canon c100 mk 2. so not much room for big lighting rigs moving with the camera, also its quite low budget film.
any thoughts?
Gabe
#2 Phil Rhodes
  • 12369 posts
Posted 21 December 2014 - 05:05 AM
I'd believe it was mainly available light, albeit available light in, what, Times Square?
  • 1
#3 Gabe Phillips
Gabe Phillips
  • 11 posts
Posted 21 December 2014 - 07:00 AM
As I will be shooting in a city with not as much ambient light as time square, does anyone have any lighting tips to get a natural look like this?
Edited by Gabe Phillips, 21 December 2014 - 07:02 AM.
#4 Jean-Marc Plante
Jean-Marc Plante
  • 33 posts
  • Montreal, Canada.
Posted 21 December 2014 - 10:18 AM
I think street sodiums give horrible flat and greenish light.
Canon C series can handle high ISOs pretty well, could you boost it a bit, LUT your image to get back the contrasts and get that natural look, and clean-up the noise after?
Edited by Jean-Marc Plante, 21 December 2014 - 10:18 AM.
#5 David Mullen ASC
  • 20413 posts
Posted 21 December 2014 - 11:25 AM
Sounds like you'll need a fast lens and mostly available light.
You can try augmenting that with a handheld battery-powered light that you dim up and down now and then, it could even be bounced into white card that someone else is walking with, to further soften the light.
#6 Gabe Phillips
Gabe Phillips
  • 11 posts
Posted 21 December 2014 - 04:55 PM
I was thinking of using a collapsible reflector to boost the light on the subjects faces while walking, using the natural ambient light around them. But this might give an un natural up lit effect.
#7 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 21 December 2014 - 05:01 PM
Couldn't you have you tallest crew member balance it on his/her shoulder?  Those things are very light.
#8 David Mullen ASC
  • 20413 posts
Posted 21 December 2014 - 05:55 PM
Just using a reflector alone would tend to under light the actors since most of your sources are high, and with streetlamp lighting tending to be flat but dim, I think it would only work now and then, like the add a little fill as someone is just passing a streetlamp.  Plus it may just make everything even flatter.
If you have a LED to point into a bounce card, at least you can pan it off and on the card to get some effect of passing lights.  You could also make a soft box attachment to something like a 1x1 LitePanel, but it probably won't be as soft as walking a 2' 4-bank Kino with heavy diffusion on the doors, or bouncing into a 4x4 card.
#9 Albion Hockney
Albion Hockney
  • 492 posts
  • LA
Posted 21 December 2014 - 06:02 PM
My Gaffer used to always take a china hat work light (can get at any hardware store) and diff it up really heavy with a way dimmed down 250w bulb for some walk and talk kinda stuff to work as a fill under sodium vapor looking lights as the color temp matched the warmth of the sodiums pretty well. For most of the stuff we were using our own lights with a Gel combo that was less green then sodium vapor but it wasnt that far off and yea it did the trick.
If the source is just for a very minimal fill so they dont go completey into darkness I dont think it needs to be super soft as you will barley notice it......but if you want it to play more and really fill them in that is a different story ....I would think like david said it will be easy for anything that really fills them in to just make the face pretty flat.
#10 Phil Rhodes
  • 12369 posts
Posted 21 December 2014 - 06:07 PM
I've got a makeshift china ball made out of a 100-watt daylight balanced compact fluorescent and a white nylon laundry bin.
Works quite well, and is collapsible.
Also tagged with one or more of these keywords: lighting, walking, low budget, city, Lighting, youtube, streets, short film, ambient light
