Lighting a horror location.
#1 Daan Werdefroy
Daan Werdefroy
  • 21 posts
  • Electrician
Posted 24 December 2014 - 10:07 AM
Hello,
I'll be shooting a horror short in 2 weekes. We just managed to arrange our principal location and now I had a small question regarding lighting for a base level.
The story will take place during 1 night and all in the same location. It's style is based on the tv-series Hannibal. The more the story progresses, the more chiaroscuro I think I will be going.
My question is regarding to the main living room. This room is quite big : 6m wide vs 15m length. Since  I would like to have a small base level of lighting I'm thinking of hanging practicals. ie chandeliers. These give light and can be put into the frame. The only thing is that I have no idea how big these should be. I'm shooting on alexa with zeis hi-speeds.
Would it be enough if each chandelier gave the equivalent of a 1K? say 10 100watt-bulbs?
I'm guessing a base leven of f4 would be very nice.
Thanks in advance
#2 Phil Rhodes
  • 12062 posts
Posted 24 December 2014 - 10:13 AM
Looks like a big soft source, probably a bit big to be a single spacelight, so maybe a big diffusion panel flown overhead, roughly over the table so they're being backlit by it. Could be a fluorescent bank of some sort.
Those sorts of lights often have to be quite powerful or by the time you've diffused it there's nothing left.
#3 David Mullen ASC
  • 19966 posts
Posted 24 December 2014 - 10:47 AM
Just make sure your chandelier can handle that much power, it may be safer to try 60w or 75w bulbs for starters, that's still going to be a pretty bright practical with 10 of those.
#4 Daan Werdefroy
Daan Werdefroy
  • 21 posts
  • Electrician
Posted 24 December 2014 - 03:18 PM
Would the chandeliers, turning some of them off for contrast, having a grid cloth between the remaining actives ones and clever blocking achieve, kinda, the same effect?
Or do I just light the wide shot with the practicals and get some kino's on booms for the CU?
I'm on a student budget, as you may have noticed  :)
Thank you David, good point. I'll have to check that.
If I may ask, what units do you tend to use for a big room, INT NIGHT ? I'm struggling to guess what unit equivalent I need just to get an ambient level.
#5 David Mullen ASC
  • 19966 posts
Posted 24 December 2014 - 04:43 PM
If the shots are very wide, then the practicals will have to do most of the work, and that will then determine the look of the tighter shots.
How I'd light a large space depends on the look I want, the needs of the story, and what the rigging issues will be -- i.e. can I rig anything to the ceiling? If not any lamps, can I mount a white sheet or something to bounce off of?  Am I better off lighting from the ground, from the side, not from above?
Obviously that example frame is lit with a big soft box overhead with a teaser all around, or at least, one for the back wall.  For a reoccurring set on a TV series, they would possibly just build a soft box with light bulbs inside, diffusion frame underneath, and a black skirt all around, hung from the grid.
