Will gelling a sodium vapor light change CRI
#1 Albion Hockney
Albion Hockney
  • 493 posts
  • LA
Posted 14 January 2015 - 04:22 PM
For night exteriors i have usually gelled tungsten lights to get them in the ballpark of sodium or other low CRI city lights.
I'm curious if light sources which are inherently give a very low color spectrum will be give a broader spectrum if gelled properly
for example can I put a little Minus Green and CTB on a sodium light to make the strong color a little more subtle.
  • 20462 posts
Posted 14 January 2015 - 04:51 PM
No, a filter by definition only removes wavelengths, it can't add missing ones.  So if you put a magenta gel on a partial spectrum source that only has a few color spikes in the green and orange range, mostly what you do is make it dimmer, it doesn't get less green, there aren't opposite wavelengths that become more prominent as a result.
  • 1
#3 Albion Hockney
Albion Hockney
  • 493 posts
  • LA
Posted 14 January 2015 - 06:04 PM
Ok makes sense! thanks much.
#4 Dennis Couzin
Dennis Couzin
  • 150 posts
  • Berlin
Posted 22 January 2015 - 11:30 PM
Every cinematographer's kit should include a spectrometer.  I used to recommend a Zeiss pocket spectroscope, but hand-held, self-contained spectrometers are now available for just $2000.  These instruments show you what's cooking in the suspect "white" light.  So you know when two are alike, when filtration might be possible, etc.
#5 Stuart Brereton
Stuart Brereton
  • 3482 posts
Posted 23 January 2015 - 12:53 AM
 self-contained spectrometers are now available for just $2000.  T.
Only $2000? Wow, I had no idea they were so cheap...
#6 John E Clark
John E Clark
  • 850 posts
  • San Diego
Posted 23 January 2015 - 05:43 PM
There's always this sort of solution... One I've been meaning to do when I have some 'spare' time...
http://publiclab.org...rometry-kit-3-0
For those who have middle schoolers in the house, this would be a good science fair project.
Edited by John E Clark, 23 January 2015 - 05:44 PM.
