Spot Meters
sekonic lighter meter spot meter
#1 Robbs
Robbs
  • 1 posts
  • Tempe
Posted 14 January 2015 - 06:50 PM
I wanted to know if I should invest in a lighter meter with a 1 degree spot meter or will a 5 degree spot meter do just fine? I'm planning to purchase the Sekonic L-478DR or the L-758cine depending on what feed back I get through this community. I'm new to this field of work and currently a student so I want something for long term and I don't want to be in a situation where I need to purchase a 1% spot meter. Thanks.
#2 John E Clark
John E Clark
  • 850 posts
  • San Diego
Posted 14 January 2015 - 07:01 PM
For me there was no question, 1 deg.
At approx 20, a 1 deg. spot will measure a 4 inch disk, roughly the area of an adult human. At 5 deg. same distance, the disk will be about 20 inchs, and so would include hair, which if contrasting the face complexion, would yield potentially a wrong reading. At at distance where a 5 deg. coves the face... it would be just as easy to walk up to the subject with either a wider (and cheaper) reflectance meter, or even an incident meter.
Of course there will be some distance where a 1 deg. yields wrong results.. but it's further out... and even in 'nature/scenics' one can get reasonably good readings with the 1 deg. for 'large' objects...
#3 Albion Hockney
Albion Hockney
  • 493 posts
  • LA
Posted 14 January 2015 - 07:42 PM
whats the difference between spot and reflectance meter?
#4 John E Clark
John E Clark
  • 850 posts
  • San Diego
Posted 14 January 2015 - 07:45 PM
A spot meter is a reflectance meter with a narrow angle of view... perhaps I sould have said a 'cheaper 30 deg. (or more) angle of view reflectance meter'...
#5 Miguel Angel
Miguel Angel
  • 900 posts
  • Spain / Ireland / South Africa
Posted 14 January 2015 - 07:48 PM
I own several light - meters that I have gotten through the years.
One of the old Sekonic ones (5º), the Minolta Spotmeter F (1º), the Minolta Autometer IV and the Spectra IV - A.
I only use the Spotmeter F and the Spectra IV - A.
My opinion is that between the two lightmeters that you are considering on buying, I would choose the L758 as you have all the lightmeters in one and it will be cheaper than buying the L478 and then the spot meter attachment or a different spot meter.
You will have everything in one device and you will have to take care of one piece of equipment as opposed as two so less hassle and less chances of leaving it on location.
The L758 has a 1º spot meter rather than the old 5º one which is very convenient.
The reason I got both light meters separately is because I have a very bad memory and when using the Sekonic, 99% of the times I forget to turn the "ball" to the right position if I change from incident to spot so the readings don't make any sense, however, it is in my bag all the times just in case something happens to my two normal light meters (I also don't like all the options that the Sekonic has, I just want to press the button and get a reading :D
In Ireland, the L758 DR is €649.99 and the L478DR is €479.99 so go for the 758 if you can afford it, you will be happier.
The difference between the 1º and the 5º measurement will come handy when planning on measuring something very small on the background or a very narrow shaft of light / rim light / patch / etc. It is also very useful when you want to take very accurate measurements of things that are very close (macro or food photography come to my mind).
Hopefully you will get more opinions so you can make up your mind! :)
Have a good day!
#6 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 14 January 2015 - 08:09 PM
If you can have only one, then I would go for the 1 degree spot. But it's nice to have the option for the wider angle. You could look for a used Sekonic L-508 or 608 on eBay and have it calibrated, since those have a 4-1 degree zoom spot. The subsequent L-558 is when Sekonic switched to a fixed 1 degree spot. My old 508 still works great.
Also tagged with one or more of these keywords: sekonic, lighter meter, spot meter
