XTRplus strange mirror Issue
#1 daniel mahlknecht
daniel mahlknecht
  • 191 posts
  • Italy - South Tyrol
Posted 30 January 2015 - 10:25 AM
I Just bought a AATON XTRplus, and found that it has strange bubbles on the rotating mirror.
Therefore it is impossible to get a sharp picture in the viewfinder.
I Atach a picture of the issue.
Does anyone know what this could be?
Toes this mean the mirror has to be replaced?
thanks
Daniel
#2 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 03 February 2015 - 05:24 AM
Looks like you need a new mirror.
#3 Mark Dunn
Mark Dunn
  • 2898 posts
Posted 03 February 2015 - 06:44 AM
Mirrors can be re-aluminised. It's not a particularly expensive process but of course it would need to be dismantled.
Edited by Mark Dunn, 03 February 2015 - 06:45 AM.
#4 daniel mahlknecht
daniel mahlknecht
  • 191 posts
Posted 05 February 2015 - 08:28 AM
Thanks for the reply.
I checked now more closely, and the mirror is definitely corroded. It's not a problem to dismantle the camera, I have some experience, I will have only to find a place that can re-aluminise the mirror.
daniel
#5 Mark Dunn
Mark Dunn
  • 2898 posts
Posted 05 February 2015 - 08:40 AM
Amateur telescope mirrors often need resilvering so an optician might be your best bet.
I found this company in the UK but there's probably no need to send it that far- there must be plenty in your part of Europe.
http://www.orionopti...rrecoating.html
The only snag is that complete removal of the glass appears to be necessary.
#6 Jean-Louis Seguin
Jean-Louis Seguin
  • 777 posts
  • Montreal, Canada
Posted 05 February 2015 - 01:34 PM
I have seen an Eclair NPR with the very same problem. Inching the shutter while looking through the viewfinder, you could the image going in and out of focus.
Jean-Louis
#7 Dom Jaeger
Dom Jaeger
  • 1923 posts
  • Melbourne, Australia
Posted 05 February 2015 - 07:21 PM
Replacing and calibrating mirror shutters is one of the hardest things to do on a film movie camera. It's easy enough to remove one, but there are a number of things that need to be checked and potentially re-set when you fit one back, including the shutter timing, the depth (or ground glass depth), the ground glass framing, and importantly the spinning flatness, which needs to be set to within about 10 microns as the shutter spins to avoid a vibrating image in the viewfinder that will make focussing very difficult and give you a headache after about 10 minutes.
Some of these settings can be retained if the whole mirror assembly is taken out complete, but to strip and re-aluminise the surface the mirror needs to be separated, so everything will need re-setting.
There is also the possibility that the corrosion that has gotten under the mirror surface has also damaged the highly polished glass substrate that creates the mirror's flat surface.  I would recommend replacing the mirror, and having the procedure done by an experienced workshop, otherwise you may spend a bit of money and still end up with an unusable camera. Admittedly I am an Arri technician and not overly familiar with Aatons, but I believe the technical realities are identical.
