How do you use scrims with PAR lenses?
#1 Andre Valune
Andre Valune
  • 10 posts
  • NYC
Posted 02 February 2015 - 05:59 PM
Hi guys -
Just a quick question - how do you use scrims with PAR lenses?  Do you jam them in between the lens and the light, or on the outer side of the lens, or do you just have to use nets on a separate c-stand to bring down the intensity?
Thanks!
  • 20085 posts
Posted 02 February 2015 - 06:08 PM
Some ParCans have the little metal tabs at the end to hold scrims.  Pars with no can often still have the holders for barn doors and should be able to take scrims.  You can try nets or ND gel, just watch out for the hot spot of the beam melting them.
#3 Andre Valune
Andre Valune
  • 10 posts
  • NYC
Posted 02 February 2015 - 06:57 PM
Great - thanks David!  And I'm thinking of Jokers specifically.  So you'd just put the scrim in between the lens and the barn doors?
#4 David Mullen ASC
  • 20085 posts
Posted 02 February 2015 - 08:16 PM
Yes if they fit.
#5 Taylor Roesch
Taylor Roesch
  • 6 posts
  • Washington, DC
Posted 18 February 2015 - 07:15 AM
Andre,
This is a constant problem with Joker fixtures.  With how convex the lenses are, they take up most of the room for scrims.  Also, constant contact with glass at those temperature can cause them to break (we broke 3 lenses on the show I just finished).  You can fit a scrim behind the lens as well if taking off light can't be done any other way.  Otherwise, ask a helpful grip to fix the problem for you.  :)
#6 Paul Salmons
Paul Salmons
  • 46 posts
Posted 18 February 2015 - 01:31 PM
Be careful dropping colds scrims into hot fixtures (room temp is fine) but if your outside on a cold day and that cold scrim touches that hot lens it will instantly crack the lens.
