Blue orb effect in 1984's Starman
visual effects orb composite flare optical printing green screen
#1 Hayden Mason
Hayden Mason
  • 14 posts
Posted 02 February 2015 - 07:04 PM
I have an upcoming project where I've been asked to film floating blue orbs around the talent a la "Starman".
My initial thought is to shoot anamorphic, float a battery powered small source on some monofillament, and composite/track over the source with a light aura of sorts (retaining the flare).
I think this MIGHT work, but in these examples there are clearly larger sources being used. They also seem to be coming from relatively the same area as the orb itself.
Due to the obvious keying/compositing (you can see the black matte lines when watching the film around the actors/windows) I was thinking maybe they keyed out a rod holding the light painted or wrapped in green? That would only really make sense with the shot from behind them.
Any attempt to contact the guys who shot these scenes has turned up unsuccessful.
Might anyone have a better idea to achieve this effect?  Obviously cameras are quite a bit more sensitive now. So, a smaller, dimmer source isn't out of the question.
Heres a video link to anyone interested:
Camera/lens package has yet to be decided.
Thanks!
#2 Hayden Mason
Hayden Mason
  • 14 posts
Posted 02 February 2015 - 07:15 PM
Also,  my scenes will not be in a car.  One is outside at night.  One is in a bedroom.  The orbs are supposed to lift from the hand and float around.
#3 Mark Dunn
Mark Dunn
  • 2797 posts
Posted 03 February 2015 - 04:39 AM
The matte lines were much less noticeable in 35mm. The extra generations have exacerbated them. But that's just the window plate, nothing to do with the orb effect. That's superimposed on a bright practical light, presumably a small halogen bulb in his hand, which doesn't move with the effect.
Edited by Mark Dunn, 03 February 2015 - 04:39 AM.
#4 Pavel Lit
Pavel Lit
  • 1 posts
Posted 03 March 2015 - 06:34 AM
may be a set of colored small LED bulbs on a pack of black cables for power, on a contrasty picture cables shouldn't be visible. Some sort of fog or diffusion filter to provide halo effect. I guess those orbs will be rising from someones palm, so the pack of bulbs on cables are being lifted and the cables are being twisted so the bulbs will be spinning in the direction of twisting...This could work I believe.
#5 Mark Dunn
Mark Dunn
  • 2797 posts
Posted 03 March 2015 - 06:37 AM
deleted
Edited by Mark Dunn, 03 March 2015 - 06:38 AM.
#6 aapo lettinen
aapo lettinen
  • 1168 posts
  • Finland
Posted 03 March 2015 - 09:35 AM
you can maybe use a customized streak filter for the effect. if you are shooting the light separately in small scale and composing it later you could maybe hide the light's power cord by fitting it inside a small black tube which is protruding out of the black background (the whole pole is behind the light source so you can just hide it behind the bright bulb  :)
Also tagged with one or more of these keywords: visual effects, orb, composite, flare, optical printing, green screen
