learning to develop film and I have very little knowledge i ordered eastman double x 5222 can i use ilford 3 to develop?
eastman5222 development
#1 Benjamin Chotka
Benjamin Chotka
  • 1 posts
Posted 06 February 2015 - 10:30 PM
How should I go about developing eastman double x 5222 can i use ilford 3? if so what times should i use?
#2 aapo lettinen
aapo lettinen
  • 1140 posts
  • Finland
Posted 07 February 2015 - 12:43 AM
yes the for example ilford 3 can be used. you should test the developing times with correctly exposed film samples and start with the basic times Ilford recommends.
You can use small 135 photo spiral tank for testing small under 1m samples and move up to bigger tanks when you have found correct times and temperatures.
you can test with different developers, it's not expensive if using small tanks with small volume
