What B&W film stock for shooting titles?
#1 Adam Cluck
Adam Cluck
  • 7 posts
  • P.A.
Posted 11 May 2005 - 08:34 PM
I'm shooting titles, and upon the advice of everyone here (many thanks!), I managed to get a clear negative (aka Kodalith). BTW, all the printing places I talked to had no idea what a Kodalith was. Most places don't use negatives anymore (let alone Kodaliths), so be prepared for a lot of shopping around.
In any event, I'll be shooting my titles by backlighting the clear negative sheets, and was wondering what B&W 16mm film to use. I'm thinking about either Double-X or Hi-Con. Considering that my source (the clear negatives) is already hi-contrast, does it make a difference whether or not I shoot using hi-con film, or will double-x do?
Many thanks!
Posted 11 May 2005 - 09:26 PM
Since you are shooting titles, assuming you can use low frame rates, then exposure is not a problem -- why not use a hi-con title stock? It would make the titles look sharper. If not, there's no reason to use Double-X -- you can use Plus-X.
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 11 May 2005 - 09:39 PM
Many thanks!
<{POST_SNAPBACK}>
The film normally used is EASTMAN High Contrast Positive Film 5363/7363:
http://www.kodak.com....4.6.6.12&lc=en
EASTMAN High Contrast Positive Film II 5363 and 7363 is a medium speed black-and-white positive film that is suitable for making both positive and negative titles. It is also useful for production of printer effects, such as silhouette and traveling mattes. This blue-sensitive film is characterized by high contrast, excellent sharpness, and very high resolving power.
#4 Adam Cluck
Adam Cluck
  • 7 posts
  • P.A.
Posted 11 May 2005 - 11:13 PM
Thanks guys for the replies!
I'm wondering if the Hi-con film is offered in 100' spools (there's no mention on Kodak's site), which I'll be shooting using a Bolex.
Also, couple more questions:
1. What is the ASA (for Tungsten) on this film?
2. Does this film need to be processed in a special way? I'm assuming that all I have to do is to ask the lab to process the Hi-con like a regular negative film. Right?
3. My film is in colour, so was wondering if the Hi-con film will cut well with the rest of my film.
Thanks again!
#5 Sam Wells
Sam Wells
  • 1751 posts
Posted 12 May 2005 - 11:33 AM
Don't know the EI - is it on Kodak's data sheet ? Roll lengths should be. I doubt if it's available in 100' rolls.
You need to talk to the lab (plus they can reccomend what EI to shoot at) -- you need a lab that can do it, (FotoKem, Alpha Cine, Du Art ? (I think)
Be careful shooting titles with a Bolex, the viewfinders can be slightly off level. A prism in the gate is the safest way.
The guy who has shot 16mm titles for me uses a Mitchell with a field chart in the finder.
You can DIY but test etc.
-Sam
#6 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
Posted 12 May 2005 - 12:45 PM
Thanks again!
<{POST_SNAPBACK}>
Processing is specified in the Kodak technical data:
http://www.kodak.com...6.12&lc=en#proc
This is the same process used for sound negatives and B&W prints.
Here is the catalog listing:
http://www.kodak.com...interfilm04.pdf
  EASTMAN High-Contrast Positive Film II 7363 / HCP451 / 16 mm x 400 ft roll / On Core / 2R-2994
1704642
Perforated Two Edges
#7 Adam Cluck
Adam Cluck
  • 7 posts
  • P.A.
Posted 12 May 2005 - 12:51 PM
Great! Thanks for all the info guys! Really helpful. :)
